Did you see that there is an updated binding available ?
Hi, yes I have done that, because openhab user does not allow me to execute the initial script.
sudo -u openhab icloud –username=xxxx@yyyyyyy.com --list deliver this error message: PermissionError: [Errno 13] Permission denied: ‘/tmp/pyicloud/openhab’. With username -u openhabian it does work. I get pyicloud working from the command line, but not from openhab UI.
I have two openhab related users on system:
- openhabian:x:1000:115:,:/home/openhabian:/bin/bash
- openhab:x:110:115:openhab runtime user,:/var/lib/openhab:/bin/false
It looks like openhab is defined as a runtime user and therefor I cannot use the user to create the keyring. Does that make sense?
Hi, can I install the new binding from the paper UI or should I manually install via .jar file?
It is an openHAB 3 binding, there is no PaperUI.
Place the .jar into your addons folder after uninstalling the old binding.
delete the folder with rm -rf /tmp/pyicloud/ (probably you need to execute it with sudo)
afterwards you can authenticate with the openhab user.
Hi, HaKuNa. I cannot authenticate with the openhab user for the earlier mentioned reasons. openhab user is a “runtime” user and gives error message: “PermissionError: [Errno 13] Permission denied: ‘/tmp/pyicloud/openhab’”
Thanks, this icloud binding is working.
I’m sure you are wrong. Your /tmp/pyicloud directory is owned by different user than openhab, therefore you get the permission error …
If you either change the owner of the directory or remove it before reauthenticate with the “correct” user, it will work.
[root@homeserver ~]# ls -al /tmp/ | grep pyicloud
drwxr-xr-x. 3 openhab openhab 60 Nov 20 18:34 pyicloud
[root@homeserver ~]# ls -al /tmp/pyicloud/
total 0
drwxr-xr-x. 3 openhab openhab 60 Nov 20 18:34 .
drwxrwxrwt. 17 root root 360 Nov 20 18:34 ..
drwx------. 2 openhab openhab 80 Oct 16 09:08 openhab
