japhias
(Jan)
August 4, 2021, 10:29pm
1
Dear all,
I started to use PersistenceExtensions. Many methods are working, but I have an issue with methods that return DecimalType like ‘deltaSince’
value = PersistenceExtensions.sumSince(ir.getItem("ITEMNAME"), ZonedDateTime.now().minusMinutes(60))
It returns in the log:
Cannot create PyString with non-byte value
How can I fix that?
Never used persistence like this myself, but work backwards from what data type the call returns and then find a way to convert that into something Jython can handle. I suspect you are getting some kind of Java structure back and you’ll need to pull out a certain property or use .toString()
Try logging the result of calling type()
and passing your persistence call.
japhias
(Jan)
August 5, 2021, 6:43pm
3
Hi Ivan,
tried somethong si,milar with str() and tested .toString(), too. Same result:
japhias
(Jan)
August 6, 2021, 5:44pm
4
Does anybody use this PersistenceExtensions?
My impression is that only a minority is using python in openhab at all.
miwok
(ND)
August 7, 2021, 5:54pm
5
Here is an example that I use and which works
OH3.1 Jython 2.7.2
from core.rules import rule
from core.triggers import when
import personal.util
reload(personal.util)
from core.actions import PersistenceExtensions
from core.log import logging, LOG_PREFIX
# OH2
#from org.joda.time import DateTime
from java.time import ZonedDateTime, ZoneId
LOG = logging.getLogger("{}.{}".format(LOG_PREFIX, rules_filename))
euroPerKwH = 0.2029
@rule("Stromverbrauch des Vortages", description = u"Stromverbrauch des Vortages Entfeucheter - " + rules_filename) # description and tags are optional
@when("Time cron 0 0 0 1/1 * ?")
def Stromverbrauch_Vortag(event):
MeterDayBegin = 0.0
MeterDayEnd = 0.0
MeterUse = 0.0
# OH2
#MeterDayBegin = PersistenceExtensions.historicState(ir.getItem("ZWaveNode2_PowerNode_ElectricMeterkWh"), DateTime.now().minusDays(1)).state
#MeterDayEnd = PersistenceExtensions.historicState(ir.getItem("ZWaveNode2_PowerNode_ElectricMeterkWh"), DateTime.now()).state
# OH3 --> das unten geht in OH2 nicht, weil "PersistenceExtensions" in OH2 nicht mit ZonedDateTime umgehen kann, in OH3 aber schon!
MeterDayBegin = PersistenceExtensions.historicState(ir.getItem("ZWaveNode2_PowerNode_ElectricMeterkWh"), ZonedDateTime.now().minusDays(1)).state
MeterDayEnd = PersistenceExtensions.historicState(ir.getItem("ZWaveNode2_PowerNode_ElectricMeterkWh"), ZonedDateTime.now()).state
if MeterDayEnd >= MeterDayBegin:
MeterUse = float(str(MeterDayEnd)) - float(str(MeterDayBegin))
else:
MeterUse = MeterDayEnd
events.postUpdate(ir.getItem("ZWaveNode2_PowerNode_ElectricMeterkwH_Day"), MeterUse)
LOG.info("powerusageDay fertig: %s", str(MeterUse))
@rule("Stromverbrauch des Vormonats", description = u"Stromverbrauch des Vormonats Entfeucheter - " + rules_filename) # description and tags are optional
@when("Time cron 0 0 0 * 1/1 ?")
def Stromverbrauch_Vormonat(event):
MeterMonthUse = 0.0
# OH2
#MeterMonthUse = PersistenceExtensions.sumSince(ir.getItem("ZWaveNode2_PowerNode_ElectricMeterkwH_Day"), DateTime.now().minusDays(DateTime.now().getDayOfMonth()))
MeterMonthUse = PersistenceExtensions.sumSince(ir.getItem("ZWaveNode2_PowerNode_ElectricMeterkwH_Day"), ZonedDateTime.now().minusDays(ZonedDateTime.now().getDayOfMonth()))
events.postUpdate(ir.getItem("ZWaveNode2_PowerNode_ElectricMeterkwH_Month"), MeterMonthUse)
LOG.info("powerusageMonth fertig: %s", str(MeterMonthUse))
@rule("Gesamtverbrauch Entfeuchter", description = u"Gesamtstromverbrauch des Entfeucheters - " + rules_filename) # description and tags are optional
def Stromverbrauch_Gesamt(event):
MeterUseSum = 0.0
# OH2
#MeterUseSum = PersistenceExtensions.sumSince(ir.getItem("ZWaveNode2_PowerNode_ElectricMeterkwH_Day"), DateTime(2019, 3, 1, 0, 0, 0, 0))
MeterUseSum = PersistenceExtensions.sumSince(ir.getItem("ZWaveNode2_PowerNode_ElectricMeterkwH_Day"), ZonedDateTime.of ( 2019, 3, 1, 0, 0, 0, 000, ZoneId.of ( "Europe/Berlin" )))
events.postUpdate(ir.getItem("ZWaveNode2_PowerNode_ElectricMeterkWhSum"), MeterUseSum)
LOG.info("powerusageSum fertig: %s", str(MeterUseSum))
japhias
(Jan)
August 7, 2021, 8:34pm
6
Thank you Andi!
This is wokring for me. I didn’t found the issue in my code, but I adapted your approach to my needs.
And it was really interesting to see how you calculate you power consumption in this rule, because I try to find a good concept for that, too.
miwok
(ND)
August 8, 2021, 7:36am
7
Hello Jan,
most of the code I got from the forum, I then adapted it to my needs. Look also here: [SOLVED] Using deltaSince to get data for every day of the week
Glad that it’s working, but like I said in my earlier post you need to determine what the persistence call is returning using type()
so that we can determine how to handle it.
miwok
(ND)
August 9, 2021, 5:29pm
9
PersistenceExtensionsType = type(PersistenceExtensions.sumSince(ir.getItem("ZWaveNode2_PowerNode_ElectricMeterkwH_Day"), ZonedDateTime.now().minusDays(ZonedDateTime.now().getDayOfMonth())))
LOG.info("PersistenceExtensionsType: {}".format(PersistenceExtensionsType))
2021-08-09 19:27:49.316 [INFO ] [jsr223.jython.test.py ] - PersistenceExtensionsType: <type 'org.openhab.core.library.types.DecimalType'>
Ah, that explains why Jython doesn’t know how to get a value from it. That data type is a custom one used by openHAB. You can use the method .intValue()
or .floatValue()
to get a value that Jython will know what to do with.
system
(system)
Closed
September 20, 2021, 10:20am
11
