I don’t really know what the best defaults would be. Ideally controlling whether or not stuff gets injected is a strong users can access through MainUI.
Beyond that, when enabled users should have access to most everything you’d usually want to do in a rule without imports like getting states of Items, commands and updates, actions, item metadata, etc. If all that is available in those two and those can be injected by default and the setting for that is accessible through the UI then it all should be good
I only posted to make sure that the UI users are not forgotten. Often choices which make perfect sense for file users and may even be programming best practices can impose a high burden on UI users, and these are the users least able to accommodate that burden.
Because I think it is a very useful feature, I just implemented it.
There is now a new release in the marketplace which implements auto injection for all non file based rules (UI Rules and Transformation Scripts). And it is configurable.
There are 3 config options now
Disabled
Enabled for all scripts
Enabled for UI and Transformation scripts (Default)
I’m trying to run my pythonscript. However, I always get the error: “ModuleNotFoundError, No module named”
I put the module in “/conf/automation/python/lib/”.
Do I have to consider anything else to continue importing modules correctly?
I’ve started writing a migration guide to help porting the old legacy helper lib scripts. However, it’s far from complete.
Since I’m lacking some perspective on your porting efforts and each perspective is different, I’m looking forward to receiving suggestions and experience reports so I can incorporate them into the guide and include relevant examples.
it contains a lot of cleanups and fixes, but the biggest highlight is the upgrade to graalvm 24.2.0. There, the highlight is, that a lot more polyglot.Foreign objects are inheriting from native python types. Means, they feel and behave like the native python object.
Foreign objects are now given a Python class corresponding to their interop traits. Foreign lists now inherit from Python list, foreign dictionaries from dict, foreign strings from str, foreign iterators from iterator, foreign exceptions from BaseException, foreign numbers from polyglot.ForeignNumber, foreign booleans from polyglot.ForeignBoolean, and foreign null values from NoneType. This means all Python methods of these types are available on the corresponding foreign objects, which behave as close as possible as if they were Python objects.
Congrats on this binding, it’s very welcome for someone who’s been looking at Jython but frustrated by the lack of Python3 compatibility.
Is this binding targeting inclusion in the upcoming Openhab 5 release?
if you want to collect early experiences with this binding, you can already install it in openhab4. There is only a “bug” which requires additional openhab restarts after the binding is installed and activated the first time. More details can be found here. Except this “bug”, it works stable and is production ready.
This is on Debian bookworm, openhab+openhab-addons 4.3.4-1; I installed from the marketplace web UI and restarted a couple of times to be sure (even though I never saw the " Native library already loaded in another classloader" message). Am I missing something?
the log line “[ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script ‘/etc/openhab/automation/python/test.py’: null” means normaly that the script has a syntax error.
I tried to reproduce it with a new clean openhab docker container and I installed the binding via marked place without any issues. I tested script created via web ui and created via script files. Both cases was working. Also an empty script was not a problem.
The message “Native library already loaded in another classloader” you get only, if there are other use cases for the graal vm, like javascript usages or js/python scripts as a transformation script.
In my test scenario I didn’t get any message too.
Could it be a permission or owner problem? Are all default options enabled in your python binding settings? If the helper libs are disabled, you get not the full error trace. In this case, you have to handle the “sys.excepthook” by your own.
Normaly, there should no DEBUG messages visible, except you changed something in the default settings.
I did use the log:set DEBUG org.openhab.automation.pythonscripting command in the console to enable debugging, but I didn’t configure anything specifically. In particular, I didn’t do anything related to the helper libs (not even sure how/where to enable/configure them), which might be the problem. I ran strace -eopenat to see what files are accessed:
/etc/openhab/automation/python/test.py is opened fine
plenty of /var/lib/openhab/.cache/org.graalvm.polyglot/python/python-home/3fe684bec8ba537cb2b83ce56e79ca175db97c1b/lib/python3.11/os.py (and similar files) are opened fine, but followed by openat(AT_FDCWD, "<frozen os>", O_RDONLY) = -1 ENOENT (No such file or directory) (not sure what to make of that)
at the end, I see a openat(AT_FDCWD, "/etc/openhab/automation/python/lib/openhab/__wrapper__.py", O_RDONLY) = -1 ENOENT (No such file or directory)
The last line looks suspicious. Should there be anything in that /etc/openhab/automation/python/lib/ dir?
Here’s an excerpt of the logs when I reinstall the binding after removing it:
2025-04-22 11:23:30.306 [DEBUG] [g.internal.PythonScriptEngineFactory] - Loading PythonScriptEngineFactory
2025-04-22 11:23:30.325 [INFO ] [g.internal.PythonScriptEngineFactory] - Deploy helper libs into /etc/openhab/automation/python/lib/openhab.
2025-04-22 11:23:30.332 [ERROR] [g.internal.PythonScriptEngineFactory] - Exception during helper lib initialisation
java.nio.file.AccessDeniedException: /etc/openhab/automation/python/lib
at sun.nio.fs.UnixException.translateToIOException(UnixException.java:90) ~[?:?]
at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:106) ~[?:?]
at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:111) ~[?:?]
at sun.nio.fs.UnixFileSystemProvider.createDirectory(UnixFileSystemProvider.java:397) ~[?:?]
at java.nio.file.Files.createDirectory(Files.java:700) ~[?:?]
at java.nio.file.Files.createAndCheckIsDirectory(Files.java:807) ~[?:?]
at java.nio.file.Files.createDirectories(Files.java:793) ~[?:?]
at org.openhab.automation.pythonscripting.internal.PythonScriptEngineFactory.initHelperLib(PythonScriptEngineFactory.java:186) ~[?:?]
at org.openhab.automation.pythonscripting.internal.PythonScriptEngineFactory.<init>(PythonScriptEngineFactory.java:94) ~[?:?]
at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) ~[?:?]
at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:77) ~[?:?]
at jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) ~[?:?]
at java.lang.reflect.Constructor.newInstanceWithCaller(Constructor.java:500) ~[?:?]
at java.lang.reflect.Constructor.newInstance(Constructor.java:481) ~[?:?]
at org.apache.felix.scr.impl.inject.internal.ComponentConstructorImpl.newInstance(ComponentConstructorImpl.java:326) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:286) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:115) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:1002) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:975) ~[?:?]
at org.eclipse.osgi.container.Module.start(Module.java:486) [org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1847) [org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136) [org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1840) [org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1783) [org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1745) [org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1667) [org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234) [org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345) [org.eclipse.osgi-3.18.0.jar:?]
2025-04-22 11:23:30.359 [DEBUG] [g.internal.PythonScriptEngineFactory] - bundle org.openhab.automation.pythonscripting:4.3.3.202503251809 (390)[org.openhab.automation.pythonscripting.internal.PythonScriptEngineFactory(395)] : getting activate: activate
