I am getting an error, which makes sense, because I am looking for a part called ‘vel’ in an json string sent by OwnTracks. OwnTracks does not send an empty ‘vel’ in case the tracker is not moving, but simply omits the item ‘vel’ altogether.
The rule is:
val String vel = transform("JSONPATH", "$.vel", json)
GeoLoc_MaxG_Vel.postUpdate(vel)
which works as long as vel is part of the json string; otherwise I get:
2019-08-19 21:30:25.574 [WARN ] [rthome.model.script.actions.BusEvent] - Cannot convert '{"t":"u","tst":1566213829,"acc":14993,"_type":"location","alt":188,"lon":152.3957915415919,"vac":20,"lat":-27.320936999704188,"batt":100,"conn":"m","tid":"MG"}' to a state type which item 'GeoLoc_MaxG_Vel' accepts: [DecimalType, QuantityType, UnDefType].
How can I test if vel is present?
I tried this, but it does not do what I expect.
if (transform("JSONPATH", "$.vel", json) === null) {
logInfo("Geo.0.1", "check vel for null.....: {}", "in if")
val String vel = "0"
} else {
logInfo("Geo.0.1", "check vel for null.....: {}", "in else")
logInfo("Geo.0.1", "check vel for null.....: {}", vel)
It actually omits that if statement altogether (as I do not get the log entries).
Any hints appreciated.
