Hello everybody
I have a strange behavior with my qubino flush dimmer (z-wave binding).
When sending the OFF command the dimmer starts turning off. While slowly dimming down it sends the current dimmer value, which is not zero. Eventually the light is off but on Paper UI it has a dimming value != 0.
Sending the first OFF command:
2018-04-25 01:05:59.474 [ome.event.ItemCommandEvent] - Item ‘KU_Dimmer’ received command OFF
2018-04-25 01:05:59.495 [vent.ItemStateChangedEvent] - KU_Dimmer changed from 100 to 0
2018-04-25 01:06:00.090 [vent.ItemStateChangedEvent] - KU_Dimmer changed from 0 to 90
2018-04-25 01:06:04.107 [vent.ItemStateChangedEvent] - KU_MetersWatts changed from 6.4 to 1.6
2018-04-25 01:06:05.118 [vent.ItemStateChangedEvent] - KU_MetersWatts changed from 1.6 to 0.5
2018-04-25 01:06:06.118 [vent.ItemStateChangedEvent] - KU_MetersWatts changed from 0.5 to 0
Why is that status update on the third line happening?
Sending the second OFF command sets the dimming value to zero:
2018-04-25 01:06:15.914 [ome.event.ItemCommandEvent] - Item ‘KU_Dimmer’ received command OFF
2018-04-25 01:06:15.946 [vent.ItemStateChangedEvent] - KU_Dimmer changed from 90 to 0
I have installed the qubino flush dimmer with firmware version 3.7
I also have a dimmer with firmware 3.5 which is not showing this behavior.
Firmware issue? Does anyone have the same behavior?
