The problem starts when upgraded form OH1 do OH2, the roller shutter module stop working.
The old OH1 configuration that works was:
Rollershutter roletaPokojLewy "Pokoj lewy [%d %%]" (rolety,roletyPietro,gPietro) { zwave="34:0:command=switch_multilevel,invert_state=false,invert_percent=true" }
And the modula has no problems at all.
After upgrade to OH2 the Thing conf is:
Rollershutter roletaPokojLewy "Pokoj lewy [%d %%]" (rolety,roletyPietro,gPietro) { channel="zwave:device:c27a85ef:node34:blinds_control1" }
According to Thing info there is no longer blinds_control (without 1 at the end).
Here is zwave.log entry when UP/DOWN action selected from UI:
root@dell:/var/log/openhab2# tail zwave.log -f |grep "NODE 34"
2017-08-10 12:09:12.050 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 34: Command received zwave:device:c27a85ef:node34:blinds_control1 --> UP
2017-08-10 12:09:12.050 [DEBUG] [erter.ZWaveMultiLevelSwitchConverter] - NODE 34: Command class SWITCH_MULTILEVEL not found when processing command on endpoint 1
2017-08-10 12:09:12.050 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 34: No messages returned from converter
2017-08-10 12:09:13.714 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 34: Command received zwave:device:c27a85ef:node34:blinds_control1 --> DOWN
2017-08-10 12:09:13.714 [DEBUG] [erter.ZWaveMultiLevelSwitchConverter] - NODE 34: Command class SWITCH_MULTILEVEL not found when processing command on endpoint 1
2017-08-10 12:09:13.714 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 34: No messages returned from converter
So it looks like the configuration or module info XML file is wrong.
Here is current module info from OH2:
Z-Wave Node 34: ZMNHCA Flush Shutter
Flush Shutter
Status: ONLINE
zwave_class_basic ROUTING_SLAVE
zwave_class_generic MULTILEVEL_SWITCH
zwave_frequent false
zwave_neighbours 17,22,32,35,43,55,58,62,65,67,69,72,80
zwave_version 1.12
zwave_listening true
zwave_deviceid 2
zwave_nodeid 34
zwave_routing true
zwave_beaming true
zwave_class_specific MOTOR_CONTROL_CLASS_C
zwave_manufacturer 345
zwave_devicetype 3
Channels
radio_button_unchecked
Switch
zwave:device:c27a85ef:node34:switch_binarycontent_copy
Switch
unfold_more
Dimmer
zwave:device:c27a85ef:node34:switch_dimmercontent_copy
Dimmer
edit unfold_more
radio_button_checked
Sensor (temperature)
zwave:device:c27a85ef:node34:sensor_temperaturecontent_copy
Number
edit unfold_more
Electric meter (watts)
zwave:device:c27a85ef:node34:meter_wattscontent_copy
Number
unfold_more
Electric meter (kWh)
zwave:device:c27a85ef:node34:meter_kwhcontent_copy
Number
unfold_more
switch
zwave:device:c27a85ef:node34:switch_binary1content_copy
Switch
unfold_more
Blinds Control
zwave:device:c27a85ef:node34:blinds_control1content_copy
Rollershutter
edit unfold_more
Temperatur Sensor
zwave:device:c27a85ef:node34:sensor_temperature1content_copy
Number
edit unfold_more
zwave:device:c27a85ef:node34:meter_watts1content_copy
Number
unfold_more
zwave:device:c27a85ef:node34:meter_kwh1content_copy
Number
Any suggestions?
