This raises the question of how you will get the signal from the RPi out of the room. I believe you mentioned previously that WiFi won’t reach reliably. Maybe that was someone else…
You can use Share Z-wave dongle over IP (USB over IP using ser2net / socat ) guide or set up federation between two openHAB instances (your main one and one running on the RPi) using MQTT if you can get WiFi.
I’d look at the logs before assuming that. Perhaps do a factory reset of the controller. There could be other explanations for the sluggishness.
