The editing needs to be done in the database directly - if you just update your own binding, then it will only be applicable for you, and will be overwritten when the binding is updated.
Thx chris. Iāll try that. (Sorry for delay answering. Been quite busy for work)
Hi @chris
Just read through the database guide and see I donāt have edit access to modify a device:
Database Instructions:
To upload an XML, select the Update Device option from the tools menu in the top right of the device summary page
I canāt see any Update device link/button on device summary page or any other page.
Is this an access right issue? If so, can you please update my access rights?
Thanks!
Luc.
Hi @chris
I found the issue and will try (if I sort out structure, definitions etcā¦) first to correct in xml to test if ok. The issue is that in zwave database, it is configured as
- Endpoint 0 (root) = OK
- Endpoint 1: IR external relay = Wrong
- endpoint 2: External relay = Wrong;
It should be as follow:
- Endpoint 0 (Root)
- Endpoint 1 : (Generic Meter)
- Endpoint 2 : External Relay
- Endpoint 3 : IR relay
The Qubino support guy also mentioned their current documentation PDF has currently errors and needs updating. Iāll try to get latest corrected doc before committing to database (if you grant me accessā¦)
I just checked, and you should already have access
On a semi-related note, the yellow colour of the āEditā button can be easily missed. perhaps make it solid colour with white text?
Thatās me forgetting to loginā¦
got the button now
OK. Iām confused. I looked (not in depth) at local zwave xml files in /var/lib/openhab2/zwave and xml export from the database and honestly Iām lost. Their structure is totally different.
Can you shed some light?
Thanks!
That is created from openHab with the data from the device itself. That file is usually used as a starting point for the database entry.
The xml export from the database is what the binding uses internally. It contains additional information not available from the device.
Hi Bruce. Thanks. I expected it would be the reason. Iāll dig into it and see if Iām smart enough to figure it out. If not, I might be back later for some help.
Hi
Have you managed to fix the problem with the data base?
I just got the same problem with Qubino Smart Meter + IR and External Relay.
Finally I got the xml file for the database: zmnhtd_0_0.xml (NOT the one in /var/lib/openhab2/zwave)
And I also got a rebuilt zwave binding witch I installed locally in my system and it looks like it did the trick - I can control both relay independently.
But any way this is a temporary solution, cause zwave database need to be fixed in order to use an official zwave binding release included in official add-on release.
So now I need help to fix this issue inside the database.
