Qubino ZMNHLD1 unknown device
I’m new with OH2 and uze it with Razzberry and Paspberry PI3.
I have problems with Qubino thermostat - ZMNHLD1. OH2 find it like “Unknown device”.
the device id : 0159:0005:0052:3.1.
I can’t find it in the database. So, how I can fix that situation?
Thank you!
That is log output in Karaf console:
00:04:40.552 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 5: Device discovery could not resolve to a thingType! 0159:0005:0052::3.1
00:04:40.556 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘zwave:device:694092b3:node5’ to inbox.
00:04:40.560 [INFO ] [smarthome.event.InboxAddedEvent ] - Discovery Result with UID ‘zwave:device:694092b3:node5’ has been added.
00:04:40.618 [INFO ] [smarthome.event.BindingEvent ] - org.openhab.binding.zwave.event.BindingEvent@1709765
00:04:45.127 [INFO ] [smarthome.event.InboxRemovedEvent ] - Discovery Result with UID ‘zwave:device:694092b3:node5’ has been removed.
00:04:45.130 [INFO ] [smarthome.event.ThingAddedEvent ] - Thing ‘zwave:device:694092b3:node5’ has been added.
00:04:45.180 [INFO ] [me.event.ThingStatusInfoChangedEvent] - ‘zwave:device:694092b3:node5’ changed from UNINITIALIZED to INITIALIZING
00:04:45.186 [INFO ] [me.event.ThingStatusInfoChangedEvent] - ‘zwave:device:694092b3:node5’ changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
00:04:45.197 [INFO ] [me.event.ThingStatusInfoChangedEvent] - ‘zwave:device:694092b3:node5’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
00:04:50.215 [WARN ] [ome.core.thing.internal.ThingManager] - Initializing handler for thing ‘zwave:device:694092b3:node5’ takes more than 5000ms.
I’ve updated the database to add your device IDs so hopefully this will be resolved when the binding is updated next.
http://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/498#overview
Hello Chris,
Thank you for the answer and assistance. How to update bindings ( or the database) on the raspberry?
Dmitry
If you are running the snapshot version, then updating is as simple as uninstalling the ZWave binding, and reinstalling it again.
Note that I’ve not updated the binding yet - I will probably do this tonight.
Thank you, will wait!
