Hello.
Z-Wave devices:
- Qubino ZMNHTD Smart Meter developed by Goap with the thing type UID of
qubino_zmnhtd_00_000
In addition to Z-Wave device I’m using: BICOM432 External IR Relay and IKA232 External Reley
Issue description:
- Not able to control External IR and External relays from openhab (paper UI or habpannel).
- Relays status is not available form the openhab
- At the same time I can control both relays with the wired hardware switch.
The rest of the channels are working good - I can read all the information.
I’ve tried to remove and re add the thing using Paper UI and via zwave.things file.
I’ve also checked those topics:
- Qubino smartmeter “switch relay” channel trigger and item update issue
- Zwave Qubino SmartMeter ZMNHTD
- ZWave: COMMAND_CLASS_SWITCH_BINARY for endpoint 2 not found
My system:
Openhab 2.5.11 Release Build
Z-Wave Binding 2.5.11
There are 15 Nodes in my Z-Wave net work
Node XML file:
node_15.xml (14.0 KB)
Z-Wave DEBUG logs:
2021-01-21 14:30:24.993 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Command received zwave:qubino_zmnhtd_00_000:controller:smartMeterKitchen:switch_binary2 --> ON [OnOffType]
2021-01-21 14:30:24.993 [DEBUG] [converter.ZWaveBinarySwitchConverter] - NODE 15: Command class class COMMAND_CLASS_SWITCH_BINARY for endpoint 2 not found
2021-01-21 14:30:24.993 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: No messages returned from converter
2021-01-21 14:30:25.896 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Command received zwave:qubino_zmnhtd_00_000:controller:smartMeterKitchen:switch_binary1 --> ON [OnOffType]
2021-01-21 14:30:25.897 [DEBUG] [converter.ZWaveBinarySwitchConverter] - NODE 15: Command class class COMMAND_CLASS_SWITCH_BINARY for endpoint 1 not found
2021-01-21 14:30:25.897 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: No messages returned from converter
Would be appreciated of any help.
Thanks.
