I’ve been researching timers in rules and have a question about how they work. I found this simple code on github
rule "do something if item state is 0 for more than 10 seconds"
Item MyItem changed
if(MyItem.state==0) {
timer = createTimer(now.plusSeconds(10)) [|
// do something!
} else {
if(timer!=null) {
timer.cancel
timer = null
It seems to me that this code does the following: when the state of MyItem changes, if it is 0 then after 10 seconds whatever code is in the “do something” section is executed.
But the description of “do something if item state is 0 for more than 10 seconds” implies to me that when MyItem initially changes state, if it is 0 but changes to 1 before the 10 seconds is up, then the timer function will not execute the code in the “do something” section.
Which is it?
For example, if MyItem happens to be a door contact and I want to check if it stays open for more than 100 seconds do I need to check the state of MyItem again after the timer ends? Do I need the second if(MyItem.state==1) part of the code in the “do something” section?
rule "do something if item state is 1 for more than 100 seconds"
Item MyItem changed
if(MyItem.state==1) {
timer = createTimer(now.plusSeconds(100)) [|
//do something
if (MyItem.state==1) {
logInfo("MyItem", "MyItem has been open for 100 seconds")
} else {
if(timer!=null) {
timer.cancel
timer = null
You would not need the second “MyItem.state==1” check because in the event that within your 100s your MyItem changes back to 1, the else statement would be executed.
In the else statement the first check
if(timer!=null) {
will check if the timer is actually running (i.e. it got started by the MyItem.state==1 trigger of the rule. If the timer is running (i.e. the 100s are not up yet), the
timer.cancel
timer = null
part will then stop the timer, in which case the code
will never execute (even without the if statement above it).
var Timer timer = null // AT THE TOP OF THE RULE FILE
Item MyItem changed
if (MyItem.state == 0) {
if (timer === null) {
timer = createTimer(now.plusSeconds(10), [ |
if (MyItem.state == 0) { // Item state is still 0 after 10s
// do something!
} else {
if(timer!=null) {
timer.cancel
timer = null
Please note that if the item has changed from 0 to something else and then reverted back to 0 in the 10s the rule will still // do something!
The previous answers are all correct but I want to explain it a little more thoroughly.
This rule triggered whenever there is a change to MyItem.
So let’s say MyItem changes to 0. Then we create a timer that will start executing in 10 seconds to // do something.
Now let’s say it is 3 seconds later and MyItem changes to 1. The Rule starts running and the if(MyItem.state == 0) is false so the else clause runs. This clause cancels the Timer if it exists which means that // do something will never run.
Now let’s assume that MyItem never changes from 0 for the full ten seconds after the Timer is created. In that case // do something happens because MyItem never changed from the 0 state.
So as you can see, the keys to the behavior are:
The Rule runs for all changes to MyItem
If a Timer exists and MyItem changes to any state other than 0, the Timer gets cancelled
Thus, // do something will only run if MyItem remains in the 0 state for 10 seconds.
Thanks! Now I get it. I was getting stuck thinking the createTimer was working like the sleep function.
What I’m actually trying to accomplish is when a door closes if there is no motion for 5 minutes then turn a light on. I was trying to do it all in one rule but now I see I will use multiple rules and access the timer from different rules.
Do not access a timer from different rules. You will run into trouble. There is a better way to do this. I am on my phone right now but look for the design pattern for timer in the forum.
I’m not sure I would say that. I can think of lots of use cases where, for example, you may want to set a timer to prevent another Rule from running for a certain amount of time after another Rule ran.
However, I do agree that in this case I don’t see why one would need separate Rules.
Hi I am also having some issues with create timer rules = I have followed the Design pattern thread and I now have lots of rules using createTimer. Should I use a separate variable for each timer at the top of the rule file? At the moment I am using createTimer without a variable eg:
rule “Wake Timmy and Dennis Monday to Friday”
Time cron "0 40 06 ? * MON-FRI "
if (Wakeup.state == ON)
logInfo(“WAKEUP.RULES”,“wakeup state is on so Dennis/Timmy alarm”)
sendCommand(Sonos_Shuffle, ON)
sendCommand(Sonos_Favorite,“Alarm”)
sendCommand(Sonos_Volume,15)
sendCommand(timmy_music,ON)
createTimer(now.plusSeconds(5), [ |
sendCommand(dennis_music,ON)
sendCommand(Lt_Dennis_Mezz,ON)
sendCommand(Lt_Timmy_Walls,ON)
else {
logInfo(“WAKEUP.RULES”,“wakeup state is off”)
I am having issues with rules not always firing (for example this one did not run this morning) and I can’t figure out why (even with logging).
There is a stray space at the end of your cron string. That may be the reason.
This is your rule tidied up a bit.
I have used the sendCommand method instead of the action.
There is no issue with your use of the timer.
rule "Wake Timmy and Dennis Monday to Friday"
Time cron "0 40 06 ? * MON-FRI"
if (Wakeup.state == ON) {
logInfo("WAKEUP.RULES", "wakeup state is on so Dennis/Timmy alarm")
Sonos_Shuffle.sendCommand(ON)
Sonos_Favorite.sendCommand("Alarm")
Sonos_Volume.sendCommand(15)
timmy_music.sendCommand(ON)
dennis_music.sendCommand(ON)
Lt_Dennis_Mezz.sendCommand(ON)
Lt_Timmy_Walls.sendCommand(ON)
} else {
logInfo("WAKEUP.RULES", "wakeup state is off")
Thanks - sorry pressed the wrong markup button, getting old need some glasses!
Well done for spotting the space.
So I can have many createTimers running concurrently in different rules without problem and without using variables? What about having more createTimers within a rule so that I don’t send too many commands at once -
eg:
Hi I’d be grateful for some advice on the logic of createTimer. I have a rule which takes a speech to text input and then based on the txt containing content in a switch case construct actions are performed. I am trying to use using multiple timers for delays and seem to have the following issue which I don’t understand.
I am running the following environment:
Release = Raspbian GNU/Linux 9 (stretch)
Kernel = Linux 4.14.98-v7+
Platform = Raspberry Pi 3 Model B Rev 1.2
openHAB 2.5.0~M1-1 (Milestone Build)
The following is an extract of a block in the rule which doesn’t work, but in my opinion looks more logical then the one further below which works fine (I ma trying to release timers to avoid increasing memory footprint):
Also I receive the following errors in my log file:
019-02-25 23:14:36.958 [ome.event.ItemCommandEvent] - Item 'VoiceCommand' received command bedtime
2019-02-25 23:14:36.974 [vent.ItemStateChangedEvent] - VoiceCommand changed from to bedtime
2019-02-25 23:14:36.990 [INFO ] [se.smarthome.model.script.Voice.Rec:] - VoiceCommand received: voicecommand (type=stringitem, state=bedtime, label=command, category=null, groups=[all])
2019-02-25 23:14:37.008 [ome.event.ItemCommandEvent] - Item 'lou_onkrec_01_har' received command PowerOff
2019-02-25 23:14:37.103 [nt.ItemStatePredictedEvent] - lou_onkrec_01_har predicted to become PowerOff
2019-02-25 23:14:37.109 [vent.ItemStateChangedEvent] - lou_onkrec_01_har changed from UNDEF to PowerOff
2019-02-25 23:14:37.114 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'VoiceControl': An error occurred during the script execution: Couldn't invoke 'assignValueTo' for feature JvmVoid: (eProxyURI: voice.rules#|::0.2.0.2.0.2.1.6.1.0.1::0::/1)
2019-02-25 23:14:37.130 [vent.ItemStateChangedEvent] - lou_onkrec_01_har changed from PowerOff to UNDEF
2019-02-25 23:14:41.014 [ome.event.ItemCommandEvent] - Item 'Sonoff_3_Switch' received command OFF
2019-02-25 23:14:41.026 [ome.event.ItemCommandEvent] - Item 'lounge_floor_light' received command OFF
2019-02-25 23:14:41.043 [ome.event.ItemCommandEvent] - Item 'hall_floor_light' received command ON
2019-02-25 23:14:41.040 [ERROR] [org.quartz.core.JobRunShell ] - Job DEFAULT.2019-02-25T23:14:41.007+01:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
<XFeatureCallImplCustom>.sendCommand(<XFeatureCallImplCustom>)
<null>.timer = <XFeatureCallImplCustom>
} ] threw an unhandled Exception:
java.lang.IllegalArgumentException: Couldn't invoke 'assignValueTo' for feature JvmVoid: (eProxyURI: voice.rules#|::0.2.0.2.0.2.1.6.1.0.1.7.6.1.1.0.3::0::/1)
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.assignValueTo(XbaseInterpreter.java:1225) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:1213) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:216) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:204) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:447) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:228) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:190) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29) ~[?:?]
at com.sun.proxy.$Proxy181.apply(Unknown Source) ~[?:?]
at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:49) ~[?:?]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [107:org.eclipse.smarthome.core.scheduler:0.11.0.oh250M1]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [107:org.eclipse.smarthome.core.scheduler:0.11.0.oh250M1]
2019-02-25 23:14:42.845 [vent.ItemStateChangedEvent] - lounge_floor_light changed from ON to OFF
2019-02-25 23:14:42.849 [vent.ItemStateChangedEvent] - hall_floor_light changed from OFF to ON
2019-02-25 23:14:42.848 [ERROR] [org.quartz.core.ErrorLogger ] - Job (DEFAULT.2019-02-25T23:14:41.007+01:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
} ] threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception.
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [107:org.eclipse.smarthome.core.scheduler:0.11.0.oh250M1]
Caused by: java.lang.IllegalArgumentException: Couldn't invoke 'assignValueTo' for feature JvmVoid: (eProxyURI: voice.rules#|::0.2.0.2.0.2.1.6.1.0.1.7.6.1.1.0.3::0::/1)
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) ~[?:?]
... 1 more
2019-02-25 23:14:49.034 [ome.event.ItemCommandEvent] - Item 'lounge_ceiling_light' received command OFF
2019-02-25 23:14:49.040 [ome.event.ItemCommandEvent] - Item 'bedroom_ceiling_light' received command 30
2019-02-25 23:14:49.045 [ome.event.ItemCommandEvent] - Item 'all_media' received command OFF
2019-02-25 23:14:49.069 [ome.event.ItemCommandEvent] - Item 'bathroom_washmachine_switch' received command OFF
2019-02-25 23:14:49.073 [ome.event.ItemCommandEvent] - Item 'Sonoff_3_Switch' received command OFF
2019-02-25 23:14:49.079 [ome.event.ItemCommandEvent] - Item 'lounge_tv' received command OFF
2019-02-25 23:14:49.085 [ome.event.ItemCommandEvent] - Item 'kitchen_music' received command OFF
2019-02-25 23:14:49.094 [ome.event.ItemCommandEvent] - Item 'lounge_music' received command OFF
2019-02-25 23:14:49.101 [nt.ItemStatePredictedEvent] - lounge_ceiling_light predicted to become OFF
2019-02-25 23:14:49.118 [nt.ItemStatePredictedEvent] - bedroom_ceiling_light predicted to become 30
2019-02-25 23:14:49.163 [vent.ItemStateChangedEvent] - lounge_ceiling_light changed from 40 to 0
2019-02-25 23:14:49.167 [vent.ItemStateChangedEvent] - bedroom_ceiling_light changed from 0 to 30
2019-02-25 23:14:49.175 [nt.ItemStatePredictedEvent] - kitchen_music predicted to become OFF
2019-02-25 23:14:49.183 [nt.ItemStatePredictedEvent] - lounge_music predicted to become OFF
This code creates a timer block scheduled for future execution, then immediately cancels it and destroys it.
It then reuses the same handle to create and schedule a timer block, and immediately cancels and destroys it again.
For clarity; you’re using a variable named timer as a container to hold a timer. That’s often useful, if you want to check or change that timer later. It works like a handle so you get hold of that scheduled code.
The action of createTimer is to make a block of code and schedule it to be run later. That’s the bit between [ ] above.
Having scheduled that, we then immediately carry on to the next line in the rest of the rule, and execute that.
In this case that’s timer.cancel, which has the obvious effect and stops that schedule.
createTimer schedules a bit of code (stuff between the [ ]) to run sometime in the future without blocking.
To block, you would use Thread::sleep. However, there are lots of reasons why that’s a bad idea so avoid using it if at all possible.
That is why your second attempt works. You schedule the code to run in 4 seconds. After 4 seconds it sends the OFF commands then you schedule another timer to run in 8 seconds ti send the last three commands.
NOTE: You should remove the timer.cancel. Hmmmm, are you sure this works? With the cancel it should prevent it from running.
So, the question is do you ever want to cancel these timers based on some other event? Or when the txt contains bedtime it will always run these Timers no matter what. If it’s the former I recommend creating two global variables to hold the timers and then schedule the two separately.
I doubt the errors you are seeing are coming from the block of code you posted.
Finally, I recommend reviewing A simple scene management: finally a good use of scripts for a potential way to better organize your scenes. I suspect this one Rule is HUGE. This might give you a way to make it more manageable and maintainable.
Many thx to you and and to rlkoshak for helping me understand this better and for your quick responses, I now see where my fault lies. Thanks also for the pointer to scene management as I think you are right it will help me manage this better
Hello!
I build a timer rule and it does not work as I want. I´ve got no ideas. Perhaps somebody can help me. The rule “bewegungsmelder an” works fine. If the rule is triggerd, for example three times, counter_1 shows in the logfiles “3”. After 10 seconds counter_1 is “0”. But the rule “bewegungsmelder aus” do not cancel the timer. If the rule “bewegungsmelder aus” is triggerd during 10 seconds, counter_1 is after 10 seconds “0”. The timer “timer_bewegungsmelder” in rule “bewegungsmelder an” will be not canceld. Where is my mistake??
var Number counter_1 = 0
var Timer timer_bewegungsmelder = null
rule "bewegungsmelder an"
Item Licht_EG_Wohnzimmer_WL_2 changed
logInfo("bewegungsmelder", "counter_1_vor= " + counter_1)
counter_1 = counter_1 + 1
timer_bewegungsmelder = createTimer(now.plusSeconds(10), [|
counter_1 = 0
logInfo("bewegungsmelder", "counter_1_nach= " + counter_1)
rule "bewegungsmelder aus"
Item Licht_EG_Wohnzimmer_WL_1 changed
timer_bewegungsmelder.cancel ()
logInfo("bewegungsmelder", "counter_1_aus= " + counter_1)
Every time rule “bewegungsmelder an” runs, it creates a new timer to run in 10 seconds time.
Every time.
A “handle” for the newly created timer is placed in your variable timer_bewegungsmelder
BUT
that on its own does not cancel any timer that variable already points to. You’ve just lost your handle, there is nothing you can do about it now.
Example -
rule triggers, 10s timer A is started. Handle points to timer A
5 secs later, rule might be triggered again. New timer B is created for 10s time. Handle updated to point to timer B. (No further control is possible over timer A, because the handle is lost)
5 secs after that, Timer A executes and sets the handle to null (No further control over timer B is possible, because the handle is lost)
5 secs after that, Timer B executes.
Look again at previous examples in this thread, and study rules that test for a null handle before creating a new timer.
At that time you can reschedule an existing timer or cancel it.
var Timer officeLightTimer = null
var timeoutMinutes = 10
rule "Office Motion Detected"
Item x10_A4_time changed
logInfo("rules", "x10_A4_time changed")
if(officeLightTimer === null){
Office_Light.sendCommand(ON)
logWarn("rules", "timer is null - creating new timer")
officeLightTimer = createTimer(now.plusMinutes(timeoutMinutes), [|
logWarn("rules", "timer executed ...")
Office_Light.sendCommand(OFF)
if(officeLightTimer != null){
logWarn("rules", "timer not null - making it so ...")
} else {
logWarn("rules", "timer is null already - do nothing ...")
} else {
logInfo("rules", "officeLightTimer not null ...")
logInfo("rules", "... so rescheduling ...")
officeLightTimer.reschedule(now.plusMinutes(timeoutMinutes))
I’m finding when this runs and x10_A4_time changes, rescheduling occurs as expected. When the changes stop (i.e. the room is not occupied), I get this error thrown:
2020-03-02 07:12:32.043 [WARN ] [eclipse.smarthome.model.script.rules] - timer not null - making it so ...
2020-03-02 10:28:08.737 [ERROR] [ersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream.
Caused by: org.eclipse.jetty.io.EofException
Caused by: java.io.IOException: Broken pipe
I’ve added the “if(officeLightTimer != null){ …” because I was getting a null pointer error by assigning the pointer to null. Should I be using timer.cancel instead of timer.null or is there another issue here?
