I have more than one rule that i want to use a timer on does that mean I have to define a timer variable for every instance I need it like the following?
var timer = null
var timer1 = null
var timer2= null
thanks
Steve
var timer = null
var timer1 = null
var timer2= null
thanks
Steve
It depends. You haven’t given us enough context to truly answer the question.
If each Rule’s timer is independent then you must define a separate variable for each. However, if each Rule is working on the timing of the same thing then you need only one variable.
I want to use the rules for turning lights off, after a set interval after they have been turned on, so i am guessing I need a seperate one for each for each rule, something like this ?
var Timer1 md1Timer = null
var Timer2 md1Timer = null
var Timer3 md1Timer = null
var Timer4 md1Timer = null
Yes, you need a separate time for each light if each light operates independently. As Garry mentioned, the Expire binding is great for this.
