I have installed the binding and created a items file with the information that interests me:
Group gopenHABServer
"Information zum openHAB Server"
<line>
(C_Technik)
/* Network information*/
String Network_AdapterName "Adapter name" <network> (gopenHABServer) { channel="systeminfo:computer:openhab:network#networkDisplayName" }
String Network_Name "Name" <network> (gopenHABServer) { channel="systeminfo:computer:openhab:network#networkName" }
String Network_IP "IP address" <network> (gopenHABServer) { channel="systeminfo:computer:openhab:network#ip" }
String Network_Mac "Mac address" <network> (gopenHABServer) { channel="systeminfo:computer:openhab:network#mac" }
Number Network_DataSent "Data sent" <flowpipe> (gopenHABServer) { channel="systeminfo:computer:openhab:network#dataSent" }
Number Network_DataReceived "Data received" <returnpipe> (gopenHABServer) { channel="systeminfo:computer:openhab:network#dataReceived" }
Number Network_PacketsSent "Packets sent" <flowpipe> (gopenHABServer) { channel="systeminfo:computer:openhab:network#packetsSent" }
Number Network_PacketsReceived "Packets received" <returnpipe> (gopenHABServer) { channel="systeminfo:computer:openhab:network#packetsReceived" }
/* CPU information*/
String CPU_Name "Name" <none> (gopenHABServer) { channel="systeminfo:computer:openhab:cpu#name" }
String CPU_Description "Description" <none> (gopenHABServer) { channel="systeminfo:computer:openhab:cpu#description" }
Number CPU_Load1 "Load (1 min)" <none> (gopenHABServer) { channel="systeminfo:computer:openhab:cpu#load1" }
Number CPU_Load5 "Load (5 min)" <none> (gopenHABServer) { channel="systeminfo:computer:openhab:cpu#load5" }
Number CPU_Load15 "Load (15 min)" <none> (gopenHABServer) { channel="systeminfo:computer:openhab:cpu#load15" }
Number CPU_Threads "Threads" <none> (gopenHABServer) { channel="systeminfo:computer:openhab:cpu#threads" }
Number CPU_Uptime "Uptime" <time> (gopenHABServer) { channel="systeminfo:computer:openhab:cpu#uptime" }
/* Drive information*/
String Drive_Name "Name" <none> (gopenHABServer) { channel="systeminfo:computer:openhab:drive#name" }
String Drive_Model "Model" <none> (gopenHABServer) { channel="systeminfo:computer:openhab:drive#model" }
String Drive_Serial "Serial" <none> (gopenHABServer) { channel="systeminfo:computer:openhab:drive#serial" }
/* Storage information*/
String Storage_Name "Name" <none> (gopenHABServer) { channel="systeminfo:computer:openhab:storage#name" }
String Storage_Type "Type" <none> (gopenHABServer) { channel="systeminfo:computer:openhab:storage#type" }
String Storage_Description "Description" <none> (gopenHABServer) { channel="systeminfo:computer:openhab:storage#description" }
Number Storage_Available "Available" <none> (gopenHABServer) { channel="systeminfo:computer:openhab:storage#available" }
Number Storage_Used "Used" <none> (gopenHABServer) { channel="systeminfo:computer:openhab:storage#used" }
Number Storage_Total "Total" <none> (gopenHABServer) { channel="systeminfo:computer:openhab:storage#total" }
Number Storage_Available_Percent "Available (%)" <none> (gopenHABServer) { channel="systeminfo:computer:openhab:storage#availablePercent" }
Number Storage_Used_Percent "Used (%)" <none> (gopenHABServer) { channel="systeminfo:computer:openhab:storage#usedPercent" }
/* Memory information*/
Number Memory_Available "Available" <none> (gopenHABServer) { channel="systeminfo:computer:openhab:memory#available" }
Number Memory_Used "Used" <none> (gopenHABServer) { channel="systeminfo:computer:openhab:memory#used" }
Number Memory_Total "Total" <none> (gopenHABServer) { channel="systeminfo:computer:openhab:memory#total" }
Number Memory_Available_Percent "Available (%)" <none> (gopenHABServer) { channel="systeminfo:computer:openhab:memory#availablePercent" }
Number Memory_Used_Percent "Used (%)" <none> (gopenHABServer) { channel="systeminfo:computer:openhab:memory#usedPercent" }
/* Swap memory information*/
Number Swap_Available "Available" <none> (gopenHABServer) { channel="systeminfo:computer:openhab:swap#available" }
Number Swap_Used "Used" <none> (gopenHABServer) { channel="systeminfo:computer:openhab:swap#used" }
Number Swap_Total "Total" <none> (gopenHABServer) { channel="systeminfo:computer:openhab:swap#total" }
Number Swap_Available_Percent "Available (%)" <none> (gopenHABServer) { channel="systeminfo:computer:openhab:swap#availablePercent" }
Number Swap_Used_Percent "Used (%)" <none> (gopenHABServer) { channel="systeminfo:computer:openhab:swap#usedPercent" }
/* Sensors information*/
Number Sensor_CPUTemp "CPU Temperature" <temperature>(gopenHABServer) { channel="systeminfo:computer:openhab:sensors#cpuTemp" }
I have not used any data to query the battery since I have openhab running on a Raspberry Pi 4 …
But oh my, the following two errors appear in the log:
2019-12-06 16:30:39.279 [ERROR] [o.internal.handler.SysteminfoHandler] - No information for channel battery#remainingTime with device intex 0 :
org.openhab.binding.systeminfo.internal.model.DeviceNotFoundException: Device with index: 0 can not be found!
at org.openhab.binding.systeminfo.internal.model.OshiSysteminfo.getDevice(OshiSysteminfo.java:101) ~[?:?]
at org.openhab.binding.systeminfo.internal.model.OshiSysteminfo.getBatteryRemainingTime(OshiSysteminfo.java:353) ~[?:?]
at org.openhab.binding.systeminfo.internal.handler.SysteminfoHandler.getInfoForChannel(SysteminfoHandler.java:304) ~[?:?]
at org.openhab.binding.systeminfo.internal.handler.SysteminfoHandler.publishDataForChannel(SysteminfoHandler.java:249) ~[?:?]
at org.openhab.binding.systeminfo.internal.handler.SysteminfoHandler.publishData(SysteminfoHandler.java:242) ~[?:?]
at org.openhab.binding.systeminfo.internal.handler.SysteminfoHandler.lambda$1(SysteminfoHandler.java:226) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:?]
and
2019-12-06 16:30:39.358 [ERROR] [o.internal.handler.SysteminfoHandler] - No information for channel battery#remainingCapacity with device intex 0 :
at org.openhab.binding.systeminfo.internal.model.OshiSysteminfo.getBatteryRemainingCapacity(OshiSysteminfo.java:365) ~[?:?]
at org.openhab.binding.systeminfo.internal.handler.SysteminfoHandler.getInfoForChannel(SysteminfoHandler.java:301) ~[?:?]
And … of course have the Binding times uninstalled and reinstalled … has brought nothing and then I once cleared the cache:
sudo /etc/init.d/openhab2 stop
sudo rm -rf /var/lib/openhab2/cache/*
sudo rm -rf /var/lib/openhab2/tmp/*
sudo /etc/init.d/openhab2 start
has brought nothing
Can someone tell me why and even better how can I fix the mistakes?
Greetings Henning
