Hello All,
I am currently trying to write a rule that will process some xml that is returned by an http request (using openhab 1.0). While going through this learning exercise I have come up with the following questions I hope someone can answer for me.
1: When writing rules, how do you know what imports to include at the top of the file?
2: Can I import any java library?
3: Is there a list of imports that are available that i can use?
4: When you write a rule like this
item (item name) trigger
(do something)
How do you know what triggers are available for that item?
Thanks for your help
Regards
Stuart
