Hello, I am having an issue with the Qubino RGBW Dimmer. Specifically with the White Channel. Whether I update the _color_temperature channel via paperui or via rest api the light turns on properly, but the item value immediately goes back to 0. This is an issue since I need to be able to read the white channel brightness when someone physically changes it via a switch on the input.
The the item value goes to 0, the physical light remains on the specified brightness.
Based on my observations, the only item/channel that changes based on real world control of the dimmer is the _color_color channel. The On/Off switch and standard dimmer values do not change at all. Is this a limitation of the database definition?
It seems that changing color temperature also changes the vause of other items?
See log snippet below:
2019-06-14 14:26:11.234 [ome.event.ItemCommandEvent] - Item ‘zwave_device_1c9b2534_node4_color_temperature’ received command 50
2019-06-14 14:26:11.239 [nt.ItemStatePredictedEvent] - zwave_device_1c9b2534_node4_color_temperature predicted to become 50
2019-06-14 14:26:11.245 [vent.ItemStateChangedEvent] - zwave_device_1c9b2534_node4_color_temperature changed from 0 to 50
2019-06-14 14:26:11.245 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_ack changed from 1327522 to 1327523
2019-06-14 14:26:11.248 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_sof changed from 3812160 to 3812161
2019-06-14 14:26:11.271 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_sof changed from 3812161 to 3812162
2019-06-14 14:26:11.273 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_ack changed from 1327523 to 1327524
2019-06-14 14:26:11.279 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_sof changed from 3812162 to 3812163
2019-06-14 14:26:11.358 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_sof changed from 3812163 to 3812164
2019-06-14 14:26:11.371 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_sof changed from 3812164 to 3812165
2019-06-14 14:26:11.375 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_ack changed from 1327524 to 1327525
2019-06-14 14:26:11.381 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_sof changed from 3812165 to 3812166
2019-06-14 14:26:11.403 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_sof changed from 3812166 to 3812167
2019-06-14 14:26:11.419 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_sof changed from 3812167 to 3812168
2019-06-14 14:26:11.423 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_ack changed from 1327525 to 1327526
2019-06-14 14:26:11.427 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_sof changed from 3812168 to 3812169
2019-06-14 14:26:11.452 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_sof changed from 3812169 to 3812170
2019-06-14 14:26:11.464 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_sof changed from 3812170 to 3812171
2019-06-14 14:26:11.468 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_ack changed from 1327526 to 1327527
2019-06-14 14:26:11.474 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_sof changed from 3812171 to 3812172
2019-06-14 14:26:11.497 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_sof changed from 3812172 to 3812173
2019-06-14 14:26:11.511 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_sof changed from 3812173 to 3812174
2019-06-14 14:26:11.514 [vent.ItemStateChangedEvent] - zwave_device_1c9b2534_node4_color_temperature changed from 50 to 0
2019-06-14 14:26:12.319 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_sof changed from 3812174 to 3812175
2019-06-14 14:26:12.339 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_sof changed from 3812175 to 3812176
2019-06-14 14:26:12.342 [vent.ItemStateChangedEvent] - zwave_device_1c9b2534_node12_meter_watts changed from 8.42 to 7.021
2019-06-14 14:26:12.757 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_ack changed from 1327527 to 1327528
2019-06-14 14:26:12.762 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_sof changed from 3812176 to 3812177
2019-06-14 14:26:12.777 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_sof changed from 3812177 to 3812178
2019-06-14 14:26:12.783 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_sof changed from 3812178 to 3812179
2019-06-14 14:26:12.786 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_ack changed from 1327528 to 1327529
2019-06-14 14:26:12.792 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_sof changed from 3812179 to 3812180
2019-06-14 14:26:12.816 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_sof changed from 3812180 to 3812181
2019-06-14 14:26:12.829 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_sof changed from 3812181 to 3812182
2019-06-14 14:26:12.834 [vent.ItemStateChangedEvent] - zwave_device_1c9b2534_node4_switch_dimmer changed from 100 to 49
2019-06-14 14:26:12.835 [vent.ItemStateChangedEvent] - zwave_device_1c9b2534_node4_color_color changed from 0,0,0 to 0,0,49
2019-06-14 14:26:12.837 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_ack changed from 1327529 to 1327530
2019-06-14 14:26:12.841 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_sof changed from 3812182 to 3812183
2019-06-14 14:26:12.863 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_sof changed from 3812183 to 3812184
2019-06-14 14:26:12.881 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_sof changed from 3812184 to 3812185
2019-06-14 14:26:12.887 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_ack changed from 1327530 to 1327531
2019-06-14 14:26:12.892 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_sof changed from 3812185 to 3812186
2019-06-14 14:26:12.913 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_sof changed from 3812186 to 3812187
2019-06-14 14:26:12.932 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_sof changed from 3812187 to 3812188
2019-06-14 14:26:12.934 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_ack changed from 1327531 to 1327532
2019-06-14 14:26:12.942 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_sof changed from 3812188 to 3812189
2019-06-14 14:26:12.960 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_sof changed from 3812189 to 3812190
2019-06-14 14:26:12.977 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_sof changed from 3812190 to 3812191
2019-06-14 14:26:12.982 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_ack changed from 1327532 to 1327533
2019-06-14 14:26:12.985 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_sof changed from 3812191 to 3812192
2019-06-14 14:26:13.011 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_sof changed from 3812192 to 3812193
2019-06-14 14:26:13.025 [vent.ItemStateChangedEvent] - zwave_serial_zstick_1c9b2534_serial_sof changed from 3812193 to 3812194
2019-06-14 14:26:13.028 [vent.ItemStateChangedEvent] - zwave_device_1c9b2534_node4_color_color changed from 0,0,49 to 0,0,0
