1, i am thinking of using a Raspberry PI zero with a dht22 sensor connected to gpio with a relay connected again to gpio pins for controlling central heating directly an a sonoff basic connected to a dehumidifier light will be conected to sonoff basic it switch wires connected to the module gpio for redundancy would this configuration work ?
2, I also i work a 4 week shift pattern can the heating/ dehumidifier be programmed around this ?
i was looking at just doing heating with the PI but i like the interface that openhab provides and should be quicker than directly programming python using flask and if i can use with dehumidifier that should work better i had started a scripty that would read a CSV file looking at the week number day and time to set the temp for the output can something similar br done or is there a better solution to this ?
So you will need to install openHABian in the pi zero. You’ll need to install Mosquitto for your MQTT broker to command the sonoffs.
The thing is, I don’t know if the pizero can handle all that. Maybe, probably actually. Have go.
Let us know how you get along, please
