I used in OH1 a mechanism to delay the rule execution during startup, as during the items loading phase some rules triggered unwanted .
Is this behaviour still existent in OH2? I want to get rid of this workaround. What is the recommendation for this workaround, if necessary?
As during startup the items change from NULL to state (ON/OFF) I could trigger
Item sq_wohnen_power changed from OFF to ON
or
Item sq_wohnen_power changed from OFF to ON or
Item sq_wohnen_power changed from ON to OFF
which replaces the single line trigger
Than the NULL event is filtered, which hopefully only applies at startup. Would this be the right solution? Or are my thoughts not correct?
It might be a better trigger to catch a command. I think at startup this are just updates and no commands. So this could be a valid solution:
Item sq_wohnen_power received command
Can you confirm this?
And a further question:
Does a change from NULL to ON trigger this
Item KinoDunkel received update ON
and how can I suppress this event during startup?
I can not say so difinitively, but I believe in OH 2 persistence and restoreOnStartup completes better any rules run. Consequently no events occur during restoreOnStartup to trigger the rules. At least that is the behavior I’m seeing. I restoreOnStartup everything and have received update, received command and changed triggered rules and none get triggered during startup.
