If I turn the switch on, I do not see a change (Standby Mode) either in the app or via the online portal. I have my polling set to ā30ā and I have waited more than 30 seconds to see the change.
I also see this in the log.
10-Feb-2018 16:00:07.731 [INFO ] [org.openhab.binding.rachio.internal.api.RachioApi ] - RachioApi: device/on failed:
java.lang.Exception: Error sending HTTP POST request to https://api.rach.io/1/public/device/on. Got responce code: 405
at org.openhab.binding.rachio.internal.util.Http.sendHttpPost(Http.java:123) [247:org.openhab.binding.rachio:2.3.0.201802082257]
at org.openhab.binding.rachio.internal.api.RachioApi.enableDevice(RachioApi.java:152) [247:org.openhab.binding.rachio:2.3.0.201802082257]
at org.openhab.binding.rachio.handler.RachioBridgeHandler.enableDevice(RachioBridgeHandler.java:155) [247:org.openhab.binding.rachio:2.3.0.201802082257]
at org.openhab.binding.rachio.handler.RachioDeviceHandler.handleCommand(RachioDeviceHandler.java:109) [247:org.openhab.binding.rachio:2.3.0.201802082257]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [109:org.eclipse.smarthome.core:0.10.0.201801231340]
at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [109:org.eclipse.smarthome.core:0.10.0.201801231340]
at com.sun.proxy.$Proxy139.handleCommand(Unknown Source) [247:org.openhab.binding.rachio:2.3.0.201802082257]
at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:72) [116:org.eclipse.smarthome.core.thing:0.10.0.201801231340]
at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:49) [116:org.eclipse.smarthome.core.thing:0.10.0.201801231340]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [109:org.eclipse.smarthome.core:0.10.0.201801231340]
10-Feb-2018 16:00:32.753 [DEBUG] [openhab.binding.rachio.handler.RachioBridgeHandler] - RachioBridgeHandler: refreshDeviceStatus
10-Feb-2018 16:01:32.755 [DEBUG] [openhab.binding.rachio.handler.RachioBridgeHandler] - RachioBridgeHandler: refreshDeviceStatus
10-Feb-2018 16:02:32.756 [DEBUG] [openhab.binding.rachio.handler.RachioBridgeHandler] - RachioBridgeHandler: refreshDeviceStatus
10-Feb-2018 16:03:32.758 [DEBUG] [openhab.binding.rachio.handler.RachioBridgeHandler] - RachioBridgeHandler: refreshDeviceStatus
10-Feb-2018 16:04:32.759 [DEBUG] [openhab.binding.rachio.handler.RachioBridgeHandler] - RachioBridgeHandler: refreshDeviceStatus
10-Feb-2018 16:05:32.761 [DEBUG] [openhab.binding.rachio.handler.RachioBridgeHandler] - RachioBridgeHandler: refreshDeviceStatus
I have run through all of the configuration screens and thought I would share a couple of thoughts Iāve had now that Iāve spent some time with the new binding:
None of these are meant to be critical, just another set of eyes looking at the work.
Squid
Controller Thing
Active Channel is called status in the channel stringā¦should it not be called the same thing as the name, either change the Channel to Status or change the channel string to Active
Channel name Evevation is misspelled should be Elevation, the channel string is correct.
Channel Online - should this be a switch or just a text field indicating the status of the Controller
Use Inital Caps on channel names to make binding look like most others. Stop watering should be Stop Watering, and Rain delay should be Rain Delay
Subtitle has a spelling error - A zone of a Rachio Sprinkeler Controller, should be A zone of a Rachio Sprinkler Controller
Zone Thing
Use Inital Caps on channel names to make binding look like most others. Zone number should be Zone Number, Zone run time should be Zone Run Time. etc.
Channel name Root deepth and channel string are misspelled. Shoud be Root Depth
Channel name Water deepth and channel string are misspelled. Shoud be Water Depth
Channel name Noizzle Name and channel string are misspelled. Shoud be Nozzle Name
Channel name Noizzle image url and channel string are misspelled. Shoud be Nozzle Image URL
Channel name Noizzle head and channel string are misspelled. Shoud be Nozzle Head
Question, should all of the channels after Zone Run Time, be hidden under an Show More button? These are items most will not look at. It could be intimadating at first with all of the channels.
Bridge Thing
Use Inital Caps on configuration parameters to make binding look like most others. Default zone runtime should be Deafult Zone Runtime
General
I wonder if for some that when you populate the Inbox should the zone number be included in the auto generated name? This was not necessary for me, just wondering aloud.
Bug
I attempted to update the configuration parameters of RACHIO bridge Thing, Default Zone Runtime and Polling/Refresh Interval. I was able to type in new values, but when clicking the check mark to save I received a 409 ERROR.
Hi, you feedback and test effort are very welcome.
Most things are already implemented:
status was renamed to active
spelling corrected + Initial caps
a new switch is implemented: Run to start all zones, or multiple (a zone is started via the zone thing):
all zones currently with runTime > 0 will be started. runTimes for zones can be selected with a rule setting appropriate items and then trigger the deviceās run switch or
the device has itās separate runTime and zoneList. If zoneList is empty and ALL zones are started. If runTime is 0 the default runtime will be used.
Watering can be stopped with the stop switch.
What do you think?
spelling corrected
Handling for run/runTime fixed
if runTime > 0: Run starts the zone for secs
if runTime = 0: Zone will be started for <bridge.defaultRuntime> secs
I donāt know about how to implement a Show More button, Paper UI does the arrangement of UI elements
done
Format is now: deviceName [zoneNumber]: zoneName
Youāll get a 409 when trying to manipulate the thing derived from the .things file. You can edit those using PaperUI. You need to edit the .things file if you want to change those settings.
get prepared, you need to delete all zones and the device, only the bridge from .things remains
(this is due to the fact that I changed the channel definition)
I disabled the nozzle channels and added run, runZones and runTime to the device.
as many time after applying a bigger number of cosmetically changes: I broke something, so canāt add the things from the inbox, PaperUI displays a 404 error - grrr, let you know when I fixed it
Just realized the ONKYO binding has the SHOW MORE button on the CONFIGURATION PARAMETERS of the THINGā¦there is only 1 parameter shown by default, after clicking SHOW MORE, you get access to 4 more.
