Rademacher Homepilot (DuoFern) via http-Binding
I would like to repost my first article which was for openHAB 2.x - but this time I changed it for openHAB3.
I used text-based configuration (instead of GUI) - because new Rademacher devices can be integrated much faster this way.
This post is a summary of all above how to integrate Rademacher Homepilot into openHAB 3. You can control Rademacher hardware like:
  • Roller Shutters, Blinds, Marquee,
  • Closing Contacts (Model 9431)
  • Sun Sensors (Model 9478)
  • Radiator Thermostat (Model 9433-1)
  • UWS (“Umweltsensor” 9475)
It was not necessary to use a workaround with FHEM or MQTT.
Prerequisites:
  • Rademacher HomePilot
  • Rademacher DuoFern shutters, blinds, sun sensors, UWS (see above)
  • openHAB http-Binding
  • openHAB JSONPath Transformation (you will find it in openHAB “other add-ons”)
First of all you need to find out your Rademacher device ID (=DID) of every single device.
The “DID” can be found for roller shutters:
http://-your-HomePilot-IP-/v4/devices
(e.g. http://192.168.1.55/v4/devices)
The URL for sensors (closing contact, sun sensor, UWS) is:
http://-your-HomePilot-IP-/v4/devices?devtype=Sensor
(e.g. http://192.168.1.55/v4/devices?devtype=Sensor)
Depending how your Browser shows JSON data you will see something like this:
If you found the DID of your Rademacher device(s) you could use this text based config files - and change it according to your landscape:
/things/rademacher.things
Thing http:url:HomePilot1 "HomePilot1" [
    baseURL="http://192.168.1.55/",  //your HomePilot IP
    authMode="BASIC",
    ignoreSSLErrors="true",
    refresh=5,
    commandMethod="PUT",
    stateMethod="GET",
    contentType="application/json",
    timeout=3000,
    bufferSize=2048,
    delay=0
    Channels:
        Type switch : Kueche_Abzugshaube [  // Rademacher plug  DID=27
            mode="WRITEONLY",
            commandExtension="/devices/27",
            onValue="{\"name\":\"TURN_ON_CMD\"}",
            offValue="{\"name\":\"TURN_OFF_CMD\"}"
        Type rollershutter : AZ_Rollladen_links [   //DID=46
            mode="WRITEONLY",
            commandExtension="/devices/46",
            stopValue="{\"name\":\"STOP_CMD\"}",
            downValue="{\"name\":\"POS_DOWN_CMD\"}",
            upValue="{\"name\":\"POS_UP_CMD\"}"
        Type number : AZ_Rollladen_links#position [
            stateExtension="/v4/devices/46",
            stateTransformation="JSONPATH:$.device.statusesMap.Position",
            commandTransformation="JS:RollerShutterPositionJSON.js",
        Type rollershutter : AZ_Rollladen_rechts [    //DID=24
            mode="WRITEONLY",
            commandExtension="/devices/24",
        Type number : AZ_Rollladen_rechts#position [
            stateExtension="/v4/devices/24",
        Type number : WC_Heizung_Battery_Percent [   // Radiator Thermostat  DID=51
            stateExtension="/v4/devices/51",
            stateTransformation="JSONPATH:$.device.batteryStatus"
            //commandExtension="/devices/51"
        Type string : WC_Heizung_Battery_Low [
            stateTransformation="JSONPATH:$.device.batteryLow"
       Type number : WC_Heizung_Regler_Position [
        Type number : WC_Heizung_actTemp [
            stateTransformation="JSONPATH:$.device.statusesMap.acttemperatur"
// ******  Sensors  ******
        Type string : WCFensterkontakt [   //clothing contact  DID=54
        stateExtension="/v4/devices?devtype=Sensor",
        stateTransformation="JSONPATH:$.meters[?(@.did==54)].readings.contact_state"
        Type number : WCFensterBattery [
        stateTransformation="JSONPATH:$.meters[?(@.did==54)].batteryStatus"
        Type string : WCFensterLowBattery [
        stateTransformation="JSONPATH:$.meters[?(@.did==54)].batteryLow"
        Type string : Sonnensensor [  // sun sensor DID=20
        stateTransformation="JSONPATH:$.meters[?(@.did==20)].readings.sun_detected"
        Type number : UWStemp [
        stateTransformation="JSONPATH:$.meters[?(@.did==43)].readings.temperature_primary"
        Type string : UWSregen [
        stateTransformation="JSONPATH:$.meters[?(@.did==43)].readings.rain_detected"
        Type number : UWSelevation [
        stateTransformation="JSONPATH:$.meters[?(@.did==43)].readings.sun_elevation"
        Type number : UWSazimut [
        stateTransformation="JSONPATH:$.meters[?(@.did==43)].readings.sun_direction"
        Type number : UWSwind [
        stateTransformation="JSONPATH:$.meters[?(@.did==43)].readings.wind_speed"
        Type number : UWSlux [
        stateTransformation="JSONPATH:$.meters[?(@.did==43)].readings.sun_brightness"
/items/rademacher.items
//Rademacher Plug
Switch        Abzugshaube    	        "Abzugshaube  [%s]"  [ "Switchable" ]                           {channel="http:url:HomePilot1:Kueche_Abzugshaube"}
//shutter
Rollershutter RollladenAZl_Strg     	"AZ Rollladen links, Steuerung"                                 {channel="http:url:HomePilot1:AZ_Rollladen_links"}
Number        RollladenAZl	            "AZ Rollladen links, Position [%d %%]"                          {channel="http:url:HomePilot1:AZ_Rollladen_links#position"}
Rollershutter RollladenAZr_Strg	        "AZ Rollladen rechts, Steuerung"                                {channel="http:url:HomePilot1:AZ_Rollladen_rechts"}
Number        RollladenAZr	            "AZ Rollladen rechts, Position [%d %%]"                         {channel="http:url:HomePilot1:AZ_Rollladen_rechts#position"}
//radiator thermostat
Number  WCheizungBattery          	    "WC Heizung Battery Percent [%d %%]"                            {channel="http:url:HomePilot1:WC_Heizung_Battery_Percent"}
String  WCheizungLowBattery       	    "WC Heizung Battery Low"                                        {channel="http:url:HomePilot1:WC_Heizung_Battery_Low"}
Number  WCheizungReglerPosition	        "WC Heizung Regler Position"                                    {channel="http:url:HomePilot1:WC_Heizung_Regler_Position"}
Number  WCheizungAktTemp  	            "WC Heizung akt. Temp. [%d]"                                    {channel="http:url:HomePilot1:WC_Heizung_actTemp"}
Number  WCheizungAktTemp_converted      "WC Heizung aktuelle Temp. converted  [%d]"
//clothing contact
String  WCFensterkontakt 	            "WC Fenster"                                                    {channel="http:url:HomePilot1:WC_Fensterkontakt"}
Number  WCFensterBattery	            "WC Fenster Battery  [%d %%]"                           		{channel="http:url:HomePilot1:WCFensterBattery"}
String  WCFensterLowBattery             "WC Fenster Low Battery"                                        {channel="http:url:HomePilot1:WCFensterLowBattery"}
//sun sensor
String Sonnensensor		 	            "Sonnensensor meldet Sonne?"                                    {channel="http:url:HomePilot1:Sonnensensor"}
//UWS
Number UWStemp					        "Temp Balkon [%.1f °C]"  [ "CurrentTemperature" ]               {channel="http:url:HomePilot1:UWStemp"}
String UWSregen					        "Regnet es?"                                                    {channel="http:url:HomePilot1:UWSregen"}
Number UWSelevation			            "Elevation (UWS) [%.1f °]"                                      {channel="http:url:HomePilot1:UWSelevation"}
Number UWSazimut		                "Azimut (UWS) [%.1f °]"                                         {channel="http:url:HomePilot1:UWSazimut"}
Number UWSwind                          "Wind (UWS) [%.1f m/s]"                                         {channel="http:url:HomePilot1:UWSwind"}
Number UWSlux                           "Helligkeit (UWS)"                                              {channel="http:url:HomePilot1:UWSlux"}
to control blinds and shutters this small js-file is needed:
/transform/RollerShutterPositionJSON.js
(function(position){
    try{
        var obj = {name: "GOTO_POS_CMD", value: parseInt(position)};
        return (JSON.stringify(obj));
    } catch(e) {
        return null;
})(input)
That’s it. :slightly_smiling_face:
I would like to thank you guys here in this forum - you helped a lot to make it perfect!
@Markus_Stein @roednix @Felix_Schneider @serg_003 @Rondo @callmed24 @danil
if you see errors, typos or improvements - please let me know. I will keep this post updated.
regards,
Kai
