I have more good news - must be switchcraft
- Meanwhile, after some cool testing session in this thread, it is possible to fully integrate a switch (relay, integrated relay in motion sensor, etc.).
This means that it is not only possible to send commands, but also the OH-internal status is updated according to the relay’s actual status. You do not need a separate channel for the status anymore! ![]()
Here is the Thing definition:
Type switch : Schalter_NL_Flur_2 "Schalter Nachtlicht Flur 2" [ // Relay switch DID=<myDID>
stateExtension="/v4/devices",
stateTransformation="JSONPATH:$.devices[?(@.did==<myDID>)].statusesMap.Position",
commandTransformation="JS:toSwitchCmd.js",
commandExtension="/devices/<myDID>",
onValue="100",
offValue="0"
and here is the associated toSwitchCmd.js:
(function(x){
try {
if (x == "0") {
return ("{\"name\":\"TURN_OFF_CMD\"}");
return ("{\"name\":\"TURN_ON_CMD\"}");
} catch(e) {
console.error('toSwitchCmd.js encountered an error: ' + e);
return null;
})(input)
And, believe it or not, I just thought I have some minutes to play around with the same idea with the rollershutters. And it almost immediately worked (with a little trick in the script). ![]()
Here’s the Thing:
Type rollershutter : Rolladen_Arbeitszimmer "Rolladen Arbeitszimmer" [ //DID=<myDID>
commandTransformation="JS:RollerShutterControlAndPos.js",
stopValue="STOP",
downValue="DOWN",
upValue="UP"
and here’s the RollerShutterControlAndPos.js script:
try{
if(x == "STOP") {
return ("{\"name\":\"STOP_CMD\"}");
if(x == "DOWN") {
return ("{\"name\":\"POS_DOWN_CMD\"}");
if(x == "UP") {
return ("{\"name\":\"POS_UP_CMD\"}");
// if it's no keyword, assume it is the position number
var obj = {name: "GOTO_POS_CMD", value: parseInt(x)};
return (JSON.stringify(obj));
} catch(e) {
console.error('RollerShutterControlAndPos.js encountered an error: ' + e);
return null;
})(input)
OH just pushes through what you command it - in case of the control buttons it’s the content of the up/down/stop value definition, and if it’s a percentage position, it’s just a number.
So the trick was to make the script distinguish between button commands via keywords, and to assume that if it’s not a keyword it must be a percentage number.
With this setup, the GUI buttons work, as well as a pure number command from a rule, and the current position is displayed in the rollershutter object itself. ![]()
