I have created a rule, and I feed in values for “WaterMeter_Output_dummy” by MQTT.
On a site map I see “WaterMeter_Output_dummy”, “Dummy_Water_Meter2” and “Dummy_Water_Meter3”. I refresh the web browser after sending each number by MQTT.
The problem is that I get random outputs from the rule. An example is below, but the output is usually not repeatable, it is a bit random when the errors occures.
I start by sending “1” 10 times
Input on “WaterMeter_Output_dummy” 2 3 4 5 6 7 8
Output on “Dummy_Water_Meter2” 1 3 3 4 5 7 7
Output on “Dummy_Water_Meter3” 1 1 3 3 4 5 7
Some time it can run rather stable with increasing values of “WaterMeter_Output_dummy”
import org.openhab.core.library.types.*
import org.openhab.core.persistence.*
import org.openhab.model.script.actions.*
import org.joda.time.*
import java.lang.Math
var Number Last_Water_Usage=0
var Number Current_Water_Usage=0
rule "Water Meter temporary usage"
Item WaterMeter_Output_dummy received update
WaterMeter_Number_New.sendCommand(Float::parseFloat(String::format("%s",WaterMeter_Output_dummy.state).replace(' ','')))
Current_Water_Usage = WaterMeter_Number_New.state as DecimalType
sendCommand(Dummy_Water_Meter2, Current_Water_Usage)
sendCommand(Dummy_Water_Meter4, Last_Water_Usage )
Last_Water_Usage = Current_Water_Usage
Why does it behave so strange?
