tabjdo
(tabjdo)
October 28, 2018, 10:38am
1
Platform information:
Hardware:Pi3
OS: _openhabian
HI Guys,
Trying to setup as razberry on raspberry
started with a naked respaberry p3
pluggeg the razberry on it
took the image
waited a long time
I got the UI working OK
use habmin great
before putting the devices I would like to check the razberry is working OK
How can I dothis ?
sihui
(SiHui)
October 28, 2018, 10:40am
2
Install the zwave binding, let your controller be autodiscovered, add it as a Thing, set the correct port.
tabjdo
(tabjdo)
October 28, 2018, 10:43am
3
thanks
fast !!!
I did nothig appears
When I trySSH it refuses the connection with openhabian:openhabian
tabjdo
(tabjdo)
October 28, 2018, 10:48am
6
okok don t shoot the newbie
looks like I have to enter the port number which I do not know how to find
sihui
(SiHui)
October 28, 2018, 10:50am
7
tabjdo:
port number
tabjdo:
No problem, but please first read the docs and then ask questions
tabjdo
(tabjdo)
October 28, 2018, 11:00am
8
apologies for disturbing sihui
I will read the doc
As run on openhabien I thought the login was coming from that OS
To summarize I need
1 to SSH to the device do figure out the serial port used
2 insert that serial port in the binding config
which puts me back to why I cannot log in the system ? with openhabian:openhabian or openhab:habopen
sihui
(SiHui)
October 28, 2018, 11:16am
9
Yes, on the command line execute dmesg -T | grep tty
This is port 22, for example using Putty on Windows.
Yes.
Up to this point you don’t have to ssh into openHAB console. You need to use your standard operating system user.
tabjdo
(tabjdo)
October 28, 2018, 3:03pm
10
I have openhabian
I dont get whr openhabian:openhabian doesnt let me in
Tried from differeng machines clients
Have you also tried PuTTY?
If yes, did you also specify the correct protocol (SSH) together with the port?
It sill can be that your SSH server is not running and the easiest way to find out would be to hook up a monitor/keyboard/mouse to your raspberry.
