Hi there,
Ive installed OH 1.7.1. on ,my raspberry pi 2+ running raspbian and it is running well. I am currently using the start.sh command to start the system as I am in development stage and need to see the event bus for trouble shooting.
I have an issue when i update the openhab configuration file and need to restart the server. I do this by closing the terminal window that start.sh created and running start.sh again. When i restart I get an error on restart like “Address already in use” i can see it referring to 0.0.0.0:8080. It looks as if closing the terminal window hasn’t killed the server properly. And actually i can still access the server. (I used this method on my Mac with out any issues). So i have two questions
Is there a different way to kill the server so it exits cleanly and will restart without the error?
if i start the openhab server at rpi boot no eventbus window is visible, is there an easy way to make it visibe without restarting the server?
I had used the apt-get procedure to start with but i couldn’t see the event bus. So i started again with a wget on the bintray repo. Looks like best thing to do is go back to the apt-get load and use the tail command.
With your current configuration, if you would like… Instead of closing the terminal, hit control-c in the window, and wait for OpenHAB to shutdown, returning you to the shell prompt. Alternately, you can also type in “exit” at the OSGi prompt. Either one should return you to the shell prompt so that you know Java is shut down cleanly.
