Hi All,
I am using Raspberry Pi 3 B with Openhab 2.3 . Influx and Grafana are on the same Pi.
Typically after every few hours system hangs . Only option is it to hard reset the power to re start .
I started monitoring Openhab Logs but no luck to note issue . All looks fine.
I did Update , Upgrade , Dist Update , update using -openhabin-config but same behaviour continue.
syslog approximately @ Hang time in not showing any error
Suggest me how to debug and find out issue
