Im new and im trying to install openhabian on a rasberrypi 3 b+.
I followed the instructions and flash my SD card with the latest openhabian image. Then i connect my raspberrypi to the internet with the ethernet cable and then inserted the SD card and turn it on.
It started to blink a green led, and the green led was kind of active for about 5 minutes, after that I have never seen the green led turnin on again. I have been here waiting and has passed more than 50 minutes and I cant resolve http://openhabianpi:8080/ neither with the IP address of the raspberrypi.
I checked my router connected client list and it appears openHABianPi so its connected.
It this a normal behavior or the green led should be active and blink all the time? Maybe is a normal behavioor and is being installed.
** UPDATE **
I just access openhabian using Putty and in the terminal I saw this:
Updating repositories and upgrading installed packages… FAILED
Appreciate any feedback.
