Hi guys,
i know that this might be more of a topic for the raspberry community but maybe some of you can give me a hint.
Hardware / SW Overview
- Release = Raspbian GNU/Linux 9 (stretch)
- Kernel = Linux 4.14.98-v7+
- Platform = Raspberry Pi 3 Model B Plus Rev 1.3
- openHAB 2.4.0-1 (Release Build)
- originally Raspberry power supply
- Raspberry directly boots from an SSD without SD card
- Razberry ZWave board
- Originally Raspberry case
Every now and then (speaking of weeks) my raspberry completely crashes. SSH is not possible and the network (LAN) is down
Today it happened again and I’ looking at the logs to identify the reason, but I can’t figure it out (or maybe i am looking at the wrong logs): The “booting” entries in the logs are me disconnecting and reconnecting the power
Syslog
Jun 20 13:03:55 openHABianPi influxd[527]: [httpd] 127.0.0.1 - openhab [20/Jun/2019:13:03:55 +0200] "POST /write?consistency=one&db=openhab_db&p=%5BREDACTED%5D&precision=n&rp=autogen&u=openhab HTTP/1.1" 204 0 "-" "okhttp/2.4.0" 185fa337$
Jun 20 13:03:57 openHABianPi influxd[527]: [httpd] 127.0.0.1 - openhab [20/Jun/2019:13:03:57 +0200] "POST /write?consistency=one&db=openhab_db&p=%5BREDACTED%5D&precision=n&rp=autogen&u=openhab HTTP/1.1" 204 0 "-" "okhttp/2.4.0" 199117f9$
Jun 20 13:02:52 openHABianPi kernel: [ 0.000000] Booting Linux on physical CPU 0x0
Messages (ttyAMA0 is the Razberry board)
Jun 20 12:17:50 openHABianPi kernel: [1170492.527093] ttyAMA ttyAMA0: 1 input overrun(s)
Jun 20 13:00:04 openHABianPi kernel: [1173027.215670] ttyAMA ttyAMA0: 1 input overrun(s)
daemon.log:
Jun 20 13:03:52 openHABianPi influxd[527]: [httpd] 127.0.0.1 - openhab [20/Jun/2019:13:03:52 +0200] "POST /write?consistency=one&db=openhab_db&p=%5BREDACTED%5D&precision=n&rp=autogen&u=openhab HTTP/1.1" 204 0 "-" "okhttp/2.4.0" 16c3aba2$
Jun 20 13:02:52 openHABianPi fake-hwclock[97]: Do 20. Jun 10:17:01 UTC 2019
Jun 20 13:02:52 openHABianPi systemd[1]: Started Create Static Device Nodes in /dev.
Jun 20 13:02:52 openHABianPi systemd[1]: Starting udev Kernel Device Manager...
So i can’t find anything helpful in those logs.
Since power supply should be sufficient, I was checking the CPU temperature as well but i couldn’t say that the temperature is unusually high. The peak at 70° C comes from rebooting. The problem itself (where you also see the reboot in the logmessages is lower, 64° C):
Is there anything else where I could find some useful information or should I think about replacing the PI since it might be a HW related problem?
Thanks for any suggestions.
