Hi there,
just started with a Raspi3 and Razby2, two Greenwave Powernodes, a Fibraro Window/Door Switch and a Popp Smoke Detector for my Home Automation. I was very happy to see, that everything was quite easy to install/configure when starting with z-way-Server, that was installed to test the Razberry. All devices were found instantly and worked fine from the first moment.
So I stopped the z-way-server, installed openhab 1.8.3 and got the two powernodes running quite easy. But now I am stuck with the Fibaro and Popp devices. Every time I start z-way-Server they are absolutely OK, but starting openhub I get some strange Messages after 5 nodes habe been found:
First, during startup (although there is no Node 255) I get:
2016-11-14 17:34:17.857 [ERROR] [WaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 2 attempts left!
2016-11-14 17:34:22.897 [ERROR] [WaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 1 attempts left!
2016-11-14 17:34:29.577 [ERROR] [WaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 0 attempts left!
2016-11-14 17:34:34.623 [WARN ] [WaveController$ZWaveSendThread] - NODE 255: Too many retries. Discarding message: Message: class = EnableSuc (0x52), type = Request (0x00), payload = 00 00
2016-11-14 17:34:39.690 [ERROR] [WaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 2 attempts left!
2016-11-14 17:34:46.087 [ERROR] [WaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 1 attempts left!
2016-11-14 17:34:52.017 [ERROR] [WaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 0 attempts left!
2016-11-14 17:34:57.066 [WARN ] [WaveController$ZWaveSendThread] - NODE 255: Too many retries. Discarding message: Message: class = SetSucNodeID (0x54), type = Request (0x00), payload = 01 00 00 00 01
Then I get a first message from the smoke Detector:
2016-11-14 17:35:01.247 [INFO ] [runtime.busevents ] - S_Finn_Rauchmelder_Batterie state updated to 100
2016-11-14 17:35:01.299 [WARN ] [.b.z.i.c.ZWaveConverterHandler] - No command class found for item = S_Finn_Rauchmelder, command class name = sensor_binary, using 0 refresh interval.
2016-11-14 17:35:01.301 [WARN ] [.b.z.i.c.ZWaveConverterHandler] - No command class found for item = S_Finn_Rauchmelder, command class name = sensor_binary, using 0 refresh interval.
2016-11-14 17:35:01.304 [WARN ] [.b.z.i.c.ZWaveConverterHandler] - No command class found for item = S_Finn_Rauchmelder_Sirene, command class name = switch_binary, using 0 refresh interval.
2016-11-14 17:35:01.306 [WARN ] [.b.z.i.c.ZWaveConverterHandler] - No command class found for item = S_Finn_Rauchmelder_Sirene, command class name = switch_binary, using 0 refresh interval.
So the battery Status is obviously readm but openhab cannot handle the smoke detector itself.
I can send a command to start the siren:
2016-11-14 17:38:01.424 [INFO ] [runtime.busevents ] - S_Finn_Rauchmelder_Sirene received command ON
But it is not handled
2016-11-14 17:37:11.481 [WARN ] [.b.z.i.c.ZWaveConverterHandler] - NODE 2: No command class found for item = S_Finn_Rauchmelder_Sirene. Class = switch_binary(SWITCH_BINARY), endpoint = 0. Ignoring command.
The Window/Door Switch keeps silent during Startup, but later reports:
2016-11-13 16:23:52.311 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 5: Unsupported command class SECURITY
2016-11-13 16:23:52.317 [ERROR] [ApplicationCommandMessageClass] - NODE 5: Unsupported command class SECURITY (0x98)
In my items-file I have the following entries for the devices:
Contact S_Finn_Rauchmelder “Rauchmelder Finn [%s]” (S_Finn) { zwave=“2:command=SENSOR_BINARY,respond_to_basic=true” }
Switch S_Finn_Rauchmelder_Sirene “Rauchmelder Finn Sirene” (S_Finn) { zwave=“2:command=switch_binary” }
Number S_Finn_Rauchmelder_Batterie “Rauchmelder Finn Batterie [%d %%]” (S_Finn) { zwave=“2:command=battery” }
Contact EG_Wohnzimmer_Terrassentuer “Terrassentür: [%s]” (EG_Wohnzimmer) { zwave=“5:command=SENSOR_BINARY,respond_to_basic=TRUE” }
Number EG_Wohnzimmer_Terrassentuer_Batterie “Terrassentür: Batterie [%s %%]” (EG_Wohnzimmer) { zwave=“5:command=BATTERY” }
Any ideas?
