- Platform information:
- Hardware: Raspberry Pi 3B+
- OS: Openhabian (updated 2nd feb 21)
- openHAB version: 3
recently i purchased the above mentioned Pi and the offical Pi Camera (raspberrypi_org/products/camera-module-v2/).
How to enable it on openhabian?
I can only find tutorials using RaspberryOS where you simply activate it in the config UI.
(eg.: How to install and use the Raspberry Pi Camera Module– The Pi Hut)
sudo raspi-config => interfacing options => camera => enable
i cant find that in the openhabian-config. i only found a workaround at
i guess openhab+Pi-onboard-camera is not meant to be …by choice, since you usually have an external controller for that?!
thanks for your input in advance
