Razberry modul working?
Dear all,
i just installed the alpha2 version as I got stuck with the 1.7. After the installation I can open up the openhab interface but I can`t see the Düwi power plug.
Is there a way to check if the zwave module on the raspberry is working?
Thanks in advance.
Knut
Check var/log/openhab/openhab.log for z-wave initialization. Did u properly configured openhab.cfg (need to set TTY PORT probably /dev/ttyAMA0). You need also to add openhab to group dialout.
