Re-activating Zigbee device after battery replacement
Every time one of my Zigbee devices runs out of battery I have a hard time re-activating the device after I replaced its battery. Even though OpenHAB shows the device as online, OpenHAB will continue to show stale data.
What is the recommended approach to re-activate Zigbee devices after battery replacement?
That said, it would be great if OpenHAB would show a timestamp when the last data was received from a device.
I can’t help with the first part as I don’t have battery powered Zigbee devices that have this problem. Just a couple of push buttons.
However, for the last part there are several options available to you.
  1. In a rule every Item has a lastStateChanged and lastStateUpdated property which is the timestamp when that Item was last updated and/or changed.
  2. With persistence configured in certain ways, you can pull that value from persistence.
  3. One can link the same Channel to a DateTime Item and use the timestamp profile to update that Item with now when the Item is updated or changed.
Thanks for your insightful reply.
Unfortunately, one of the main pain points is the “Zigbee device runs out of battery” story. I can’t imagine that the only way to re-activate the device is to delete it and re-pair it. Surely there exists a more user friendly story that I simply don’t know.
