hi
my openhab been find alll day and when I installed two binding
and now its not working ** dpkg-query: no packages found matching openhab2
sed: can’t read /var/lib/openhab2/etc/version.properties: No such file or directory**
said that on terminal
and openhab page not found http error
don’t know what when wrong
hope this helps
many thanks Oliver
Alien
(Rafał Różynek)
May 10, 2020, 9:31pm
2
Can you provide more information, what hardware?
im on raspberry pi 3b but when I try and find the log flies in the main files. there are no log files
matt1
(Skinah)
May 11, 2020, 11:08am
5
Try restarting three times.
I try that but did not work. could it be the update that did it?
Alien
(Rafał Różynek)
May 11, 2020, 11:27am
7
If you have OH on an SD card, it may be corrupted.
don’t think it is because it works on terminal
im going to install it again nothing is working what do I format the sd card to because using Ethcher flasher
Alien
(Rafał Różynek)
May 11, 2020, 12:48pm
10
Corrupted doesn’t means dead.
matt1
(Skinah)
May 11, 2020, 1:37pm
11
Most times a sd card becomes corrupted and the card is perfectly fine when formatted again. Re use the card as most time’s it is fine depending on how u have been using the card.
thanks matt
just reformatted it and put openhab on will try it in pi
paulo9999
(Paulo Wang)
November 17, 2020, 10:59am
13
Hi, I have the same issue, but this was because I upgraded OH to the 3.0 version, so the openhab2 folders doesn’t exist anymore. I don’t know how to solve this problem too…
