Re-size slider
1.8 and Classic UI, I have a dimmer switch with a slider. On the phone the slider is very tiny and unusable. To use it you have to turn the phone sideways. Is there anyway to re-size the item widget so that the slider goes underneath the label? Basically, make the widget twice as tall?
I have the same problem. Did you find a solution?
Try shortening the name. I think that’s what I did. Basically, the label has priority and will compress the slider.
