I have running openHAB on raspberry3 with 2 ESP8266 NodeMCUs they send data to my MQTT and data is show in openhab “Great and it works”!
I use this lines in items:
Number TestTemperature "Temperatur Schuppen [%.1f C]" <temperature> (GF_Living) {mqtt="<[broker:home/temperaturewz:state:default]"} Number TestTemperature2 "Temperatur Dachgeschoss [%.1f C]" <temperature> (GF_Living) {mqtt="<[broker:home/temperatureoben:state:default]"}
Now i have installed weewx mqtt extension on my weather raspberry2, i can subscribe to the topic from my raspberry3 with:
mosquitto_sub -h 192.168.0.40 -v -t '/home/#'
that gives me an output every 5 minutes:
/home/weather/barometer_inHg 29.7709589813 /home/weather/outHumidity 81.0 /home/weather/windGust_mph 2.2369362912 /home/weather/interval_minute 5.0 /home/weather/dewpoint_F 41.5937551087 /home/weather/rain_in 0.0 /home/weather/ptr 30528.0 /home/weather/dayRain_in 0.20078740137 /home/weather/heatindex_F 47.12 /home/weather/outTempBatteryStatus 0.0 /home/weather/altimeter_inHg 29.761940599 /home/weather/delay 5.0 /home/weather/windrun_mile 35.8618169751 /home/weather/inDewpoint 54.0255021751 /home/weather/outTemp_F 47.12
i have definied this mqtt broker in openhab.config with:
mqtt:broker.url=tcp://localhost:1883 mqtt:weatherbroker.url=tcp://192.168.0.40:1883
and both to:
mqtt:broker.retain=true mqtt:weatherbroker.retain=true
now i want the data showing in my items, i use in items for outTemp_F:
Number TestTemperature3 "Temperatur WetterStation [%.1f C]" <temperature> (GF_living){mqtt="<[brokerweather:home/weather/out_Temp_F:state:default]"}
my default sitemap is also correct:
/opt/openhab/configurations/sitemaps/default.sitemap 180/180 100% sitemap default label="Haus" { Frame label="Temperaturen" { Text item=TestTemperature Text item=TestTemperature2 Text item=TestTemperature3 } }
The Data from weatherbroker is not showing
My question is how to include my weaterstation data to openHAB.
Is this a beginner question?
