- Platform information:
- Hardware: Raspberry Pi 4b 8GB
- OS: openhabian image (debian I assume)
- Java Runtime Environment: openjdk version 11.0.9
- openHAB version: 3.0.0 release build
- Issue of the topic:
I am trying to read a temperature / humidity number value from a JSON string. The string is provided by mosquitto. I created an MQTT Broker Thing to connect to mosquitto and a generic MQTT thing to get the data from my MQTT broker client thing. Reading the values using a string channel works fine, but then applying rules for notifications becomes a problem.
I am using the UI to configure everything and I hope reading a number value is supported that way.
I tried to replace the string channel wit a number channel, which I then bound to a number item. However, the number item remains NULL while the corresponding string channel/item contains the correct value.
How can I get the number parsed from the JSON string? I read the key thing is to use a number channel and to link it with a number item.
The JSON string looks like this:
{"battery":97,"device":{"applicationVersion":2,"dateCode":"20160516","friendlyName":"TEMP_SCHLAFZIMMER","hardwareVersion":30,"ieeeAddr":"0x00158d00045c449b","manufacturerID":4151,"manufacturerName":"LUMI","model":"WSDCGQ01LM","networkAddress":60482,"powerSource":"Battery","softwareBuildID":"3000-0001","stackVersion":2,"type":"EndDevice","zclVersion":1},"humidity":62.36,"linkquality":15,"temperature":22.04,"voltage":2995}
As you can see the value is not enclosed in quotes.
What am I missing?
- Please post configurations (if applicable):
My things are:
`UID: mqtt:topic:aa0181d1ad:9c50b08453
label: Generic MQTT Thing
thingTypeUID: mqtt:topic
configuration: {}
bridgeUID: mqtt:broker:aa0181d1ad
channels:
- id: Humidity
channelTypeUID: mqtt:string
label: Humidity
description: “”
configuration:
transformationPattern: JSONPATH:$.humidity
stateTopic: “#” - id: Temperatur-Schlafzimmer
label: Temperatur-Schlafzimmer
description: “”
configuration:
stateTopic: “#”
transformationPattern: jsonpath:$.temperature - id: HumidityNum
channelTypeUID: mqtt:number
label: HumidityNum
description: “”
configuration:
min: 0
stateTopic: “#”
max: 100`
- If logs where generated please post these here using code fences:
events.log (excerpt):
2021-01-02 21:09:42.445 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'GenericMQTTThing_Humidity' changed from 68.9 to 79.16 2021-01-02 21:09:47.665 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'GenericMQTTThing_TemperaturSchlafzimmer' changed from 21.97 to 22.08 2021-01-02 21:09:47.685 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'GenericMQTTThing_Humidity' changed from 79.16 to 69.47 2021-01-02 21:09:52.893 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'GenericMQTTThing_TemperaturSchlafzimmer' changed from 22.08 to 22.04 2021-01-02 21:09:52.904 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'GenericMQTTThing_Humidity' changed from 69.47 to 62.36 2021-01-02 21:11:58.567 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'GenericMQTTThing_TemperaturSchlafzimmer' changed from 22.04 to 21.7 2021-01-02 21:11:58.575 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'GenericMQTTThing_Humidity' changed from 62.36 to 57.61
openhab.log (excerpt):
`2021-01-02 21:15:34.276 [ERROR] [rg.apache.cxf.jaxrs.utils.JAXRSUtils] - Problem with writing the data, class org.openhab.core.io.rest.sitemap.internal.PageDTO, ContentType: application/json
2021-01-02 21:15:34.283 [WARN ] [ache.cxf.phase.PhaseInterceptorChain] - Interceptor for {http://internal.id.core.openhab.org/}UUIDResource has thrown exception, unwinding now
org.apache.cxf.interceptor.Fault: Closed
at org.apache.cxf.jaxrs.interceptor.JAXRSOutInterceptor.handleWriteException(JAXRSOutInterceptor.java:396) ~[bundleFile:1.0.9]
at org.apache.cxf.jaxrs.interceptor.JAXRSOutInterceptor.serializeMessage(JAXRSOutInterceptor.java:272) ~[bundleFile:1.0.9]
at org.apache.cxf.jaxrs.interceptor.JAXRSOutInterceptor.handleWriteException(JAXRSOutInterceptor.java:398) ~[bundleFile:1.0.9]
at org.apache.cxf.jaxrs.interceptor.JAXRSOutInterceptor.processResponse(JAXRSOutInterceptor.java:122) ~[bundleFile:1.0.9]
at org.apache.cxf.jaxrs.interceptor.JAXRSOutInterceptor.handleMessage(JAXRSOutInterceptor.java:84) ~[bundleFile:1.0.9]
at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:308) [bundleFile:1.0.9]
at org.apache.cxf.interceptor.OutgoingChainInterceptor.handleMessage(OutgoingChainInterceptor.java:90) [bundleFile:1.0.9]
at org.apache.cxf.transport.ChainInitiationObserver.onMessage(ChainInitiationObserver.java:121) [bundleFile:1.0.9]
at org.apache.cxf.transport.http.AbstractHTTPDestination.invoke(AbstractHTTPDestination.java:267) [bundleFile:1.0.9]
at org.apache.cxf.transport.servlet.ServletController.invokeDestination(ServletController.java:234) [bundleFile:1.0.9]
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:208) [bundleFile:1.0.9]
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:160) [bundleFile:1.0.9]
at org.apache.cxf.transport.servlet.CXFNonSpringServlet.invoke(CXFNonSpringServlet.java:216) [bundleFile:1.0.9]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.handleRequest(AbstractHTTPServlet.java:301) [bundleFile:1.0.9]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.doGet(AbstractHTTPServlet.java:225) [bundleFile:1.0.9]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687) [bundleFile:3.1.0]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.service(AbstractHTTPServlet.java:276) [bundleFile:1.0.9]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:852) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:544) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:536) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1581) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1307) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) [bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:482) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1549) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1204) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [bundleFile:?]
at org.eclipse.jetty.server.Server.handle(Server.java:494) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:374) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:268) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:367) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:782) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:918) [bundleFile:9.4.20.v20190813]
Caused by: org.eclipse.jetty.io.EofException: Closed
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:492) ~[bundleFile:9.4.20.v20190813]
at org.apache.cxf.io.AbstractWrappedOutputStream.write(AbstractWrappedOutputStream.java:51) ~[bundleFile:1.0.9]
at org.apache.cxf.io.AbstractWrappedOutputStream.write(AbstractWrappedOutputStream.java:60) ~[bundleFile:1.0.9]
at org.openhab.core.io.rest.core.internal.GsonMessageBodyWriter.writeTo(GsonMessageBodyWriter.java:84) ~[?:?]
at org.openhab.core.io.rest.core.internal.MediaTypeExtension.writeTo(MediaTypeExtension.java:84) ~[?:?]
at org.apache.cxf.jaxrs.utils.JAXRSUtils.writeMessageBody(JAXRSUtils.java:1451) ~[bundleFile:1.0.9]
at org.apache.cxf.jaxrs.interceptor.JAXRSOutInterceptor.serializeMessage(JAXRSOutInterceptor.java:246) ~[bundleFile:1.0.9]
... 50 more
2021-01-02 21:15:39.542 [ERROR] [rg.apache.cxf.jaxrs.utils.JAXRSUtils] - Problem with writing the data, class org.openhab.core.io.rest.sitemap.internal.PageDTO, ContentType: application/json
2021-01-02 21:15:39.548 [WARN ] [ache.cxf.phase.PhaseInterceptorChain] - Interceptor for {http://internal.id.core.openhab.org/}UUIDResource has thrown exception, unwinding now
... 50 more`
