Reading Data from Solaredge inverters via Modbus TCP
Hello Everybody,
im activated Modbus TCP on my SE Inverter.
Then i make copy&paste all Files from this Posting, edit the TCP IP Adress in the Config and hope to get some data. But - Nothing.
And here All Files and a Log there is some Error but i don´t know how to fix them.
modbus.cfg
poll=10000
tcp.se9k.connection=192.168.178.26:502:60:0:0:3:500
tcp.se9k.id=1
tcp.se9k.type=holding
tcp.se9k.start=69
tcp.se9k.length=50
tcp.se9k.valuetype=uint16
/etc/openhab2/items/solaredge9k.items
Group se9kint "Wechselrichter PV-Anlage (int-Werte)"
Group se9k "Wechselrichter PV-Anlage"
Number se9k_DID_int “WR Typ (int) [%d]” (se9kint) {modbus=“se9k:0”}
// Amps acrosss all phases
Number se9k_Amps_int “WR Stromerzeugung gesamt (int) [%d A]” (se9kint) { modbus=“se9k:2” }
// Amps Phase A,B,C and scaling factor
Number se9k_AmpA_int “WR Stromerzeugung Ph.A (int) [%d A]” (se9kint) { modbus=“se9k:3” }
Number se9k_AmpB_int “WR Stromerzeugung Ph.B (int) [%d A]” (se9kint) { modbus=“se9k:4” }
Number se9k_AmpC_int “WR Stromerzeugung Ph.C (int) [%d A]” (se9kint) { modbus=“se9k:5” }
Number se9k_AmpSF_int “WR Skalierungsfaktor Strom (int) [%d]” (se9kint) { modbus=“se9k:6” }
// Voltage for Phases A,B,C and scaling factor
Number se9k_VoltA_int “WR Spannung Phase A (int) [%d V]” (se9kint) { modbus=“se9k:10” }
Number se9k_VoltB_int “WR Spannung Phase B (int) [%d V]” (se9kint) { modbus=“se9k:11” }
Number se9k_VoltC_int “WR Spannung Phase C (int) [%d V]” (se9kint) { modbus=“se9k:12” }
Number se9k_VoltSF_int “WR Skalierungsfaktor Spannung (int) [%d]” (se9kint) { modbus=“se9k:13” }
// Power and SF
Number se9k_Watt_int “WR Leistung Erzeugung (int) [%d W]” (se9kint) { modbus=“se9k:14” }
Number se9k_WattSF_int “WR Skalierungsfaktor Leistung (int) [%d]” (se9kint) { modbus=“se9k:15” }
// Frequency and SF
Number se9k_Hz_int “WR Netzfrequenz (int) [%d Hz]” (se9kint) { modbus=“se9k:16” }
Number se9k_HzSF_int “WR Skalierungsfaktor Netzfrequ. (int) [%d]” (se9kint) { modbus=“se9k:17” }
// Apparent Power and SF
Number se9k_VA_int “WR Scheinleistung gesamt (int) [%d VA]” (se9kint) { modbus=“se9k:18” }
Number se9k_VASF_int “WR Skalierungsfaktor Scheinleistung (int) [%d]” (se9kint) { modbus=“se9k:19” }
// Reactive Power and SF
Number se9k_VAR_int “WR Reaktive Leistung gesamt (int) [%d VA]” (se9kint) { modbus=“se9k:20” }
Number se9k_VARSF_int “WR Skalierungsfaktor reaktive Leistung (int) [%d]” (se9kint) { modbus=“se9k:21” }
// Power factor
Number se9k_PF_int “WR Leistungsfaktor (int) [%d cos phi]” (se9kint) { modbus=“se9k:22” }
Number se9k_PFSF_int “WR Skalierungsfaktor Leistungsfaktor (int) [%d]” (se9kint) { modbus=“se9k:23” }
// Lifetime generated energy
Number se9k_Wh1_int “WR Erzeugungszaehler Byte1 (int) [%d Wh]” (se9kint) { modbus=“se9k:24” }
Number se9k_Wh2_int “WR Erzeugungszaehler Byte2 (int) [%d Wh]” (se9kint) { modbus=“se9k:25” }
Number se9k_WhSF_int “WR Skalierungsfaktor Zaehler (int) [%d]” (se9kint) { modbus=“se9k:26” }
// DC side current
Number se9k_DCA_int “WR Strom DC Seite (int) [%d A]” (se9kint) { modbus=“se9k:27” }
Number se9k_DCASF_int “WR Skalierungsfaktor DC Strom (int) [%d]” (se9kint) { modbus=“se9k:28” }
// DC side voltage
Number se9k_DCV_int “WR Spannung DC Seite (int) [%d V]” (se9kint) { modbus=“se9k:29” }
Number se9k_DCVSF_int “WR Skalierungsfaktor DC Spannung (int) [%d]” (se9kint) { modbus=“se9k:30” }
// DC side power
Number se9k_DCW_int “WR Leistung DC Seite (int) [%d W]” (se9kint) { modbus=“se9k:31” }
Number se9k_DCWSF_int “WR Skalierungsfaktor DC Leistung (int) [%d]” (se9kint) { modbus=“se9k:32” }
// Temp Heat sink
Number se9k_THS_int “WR Temperatur Kuehlkorper (int) [%d C]” (se9kint) { modbus=“se9k:34” }
Number se9k_THSSF_int “WR Skalierungsfaktor Kuehlkoerper (int) [%d]” (se9kint) { modbus=“se9k:37” }
// Operating state
Number se9k_Status_int “WR Status (int) [%d]” (se9kint) { modbus=“se9k:38” }
Number se9k_Status_Vendor_int “WR Status Vendor (int) [%d]” (se9kint) { modbus=“se9k:39” }
// Se9K inverter Float values
String se9k_DID “WR Typ [%s]” (se9k)
Number se9k_Amps “WR Stromerzeugung gesamt [%.2f A]” (se9k)
// Amps Phase A,B,C
Number se9k_AmpA “WR Stromerzeugung Ph.A [%.2f A]” (se9k)
Number se9k_AmpB “WR Stromerzeugung Ph.B [%.2f A]” (se9k)
Number se9k_AmpC “WR Stromerzeugung Ph.C [%.2f A]” (se9k)
Number se9k_VoltA “WR Spannung Phase A [%.1f V]” (se9k)
Number se9k_VoltB “WR Spannung Phase B [%.1f V]” (se9k)
Number se9k_VoltC “WR Spannung Phase C [%.1f V]” (se9k)
// Power
Number se9k_Watt “Erzeugungsleistung Photovolaik [%.2f W]” (se9k)
// Frequency
Number se9k_Hz “WR Netzfrequenz [%.2f Hz]” (se9k)
// Apparent Power
Number se9k_VA “WR Scheinleistung gesamt [%.2f VA]” (se9k)
// Reacive Power
Number se9k_VAR “WR reaktive Leistung gesamt [%.2f VA]” (se9k)
// Power factor
Number se9k_PF “WR Leistungsfaktor [%.1f cos phi]” (se9k)
Number se9k_kWh “WR Erzeugungszaehler [%.3f kWh]” (se9k)
// the follwing two items allow you to display some derived values, i.e. the energy produced in the current year.
Number se9k_kWh_Jahr “WR Erzeugung seit Jahresanfang [%.3f kWh]” (se9k)
Number se9k_kWh_Jahr_Offset “WR Offset Erzeugungaehler zum 1.1. [%.3f kWh]” (se9k)
// DC side current
Number se9k_DCA “WR Strom DC Seite [%.2f A]” (se9k)
// DC side voltage
Number se9k_DCV “WR Spannung DC Seite [%.2f V]” (se9k)
// DC side power
Number se9k_DCW “WR Leistung DC Seite [%.2f W]” (se9k)
// Temp Heat sink
Number se9k_THS “WR Temperatur Kuehlkorper [%.2f C]” (se9k)
// Status
String se9k_Status “Status [%s]” (se9k)
String se9k_Status_Vendor “Status Vendor [%s]” (se9k)
/etc/openhab2/rules/solaredge9k.rules
import java.lang.Math
import java.lang.Double
rule se9k_Amps_add
when Item se9k_Amps_int received update
var Double SF = (se9k_AmpSF_int.state as DecimalType).doubleValue
if (SF > 32767) SF = SF-(65536).doubleValue
var Double result = (se9k_Amps_int.state as DecimalType).doubleValue * Math::pow(10,SF)
var String value = result.toString
logDebug("SE9K WR Stromerzeugung gesamt: ", value)
postUpdate(se9k_Amps, result)
rule se9k_AmpA_add
when Item se9k_AmpA_int received update
var Double result = (se9k_AmpA_int.state as DecimalType).doubleValue * Math::pow(10,SF)
logDebug("SE9K WR Strom Phase A: ", value)
postUpdate(se9k_AmpA, result)
rule se9k_AmpB_add
when Item se9k_AmpB_int received update
var Double result = (se9k_AmpB_int.state as DecimalType).doubleValue * Math::pow(10,SF)
logDebug("SE9K WR Strom Phase B: ", value)
postUpdate(se9k_AmpB, result)
rule se9k_AmpC_add
when Item se9k_AmpC_int received update
var Double result = (se9k_AmpC_int.state as DecimalType).doubleValue * Math::pow(10,SF)
logDebug("SE9K WR Strom Phase C: ", value)
postUpdate(se9k_AmpC, result)
rule se9k_VoltA_add
when Item se9k_VoltA_int received update
var Double SF = (se9k_VoltSF_int.state as DecimalType).doubleValue
var Double result = (se9k_VoltA_int.state as DecimalType).doubleValue * Math::pow(10,SF)
logDebug("SE9K WR Spannung Phase A: ", value)
postUpdate(se9k_VoltA, result)
rule se9k_VoltB_add
when Item se9k_VoltB_int received update
var Double result = (se9k_VoltB_int.state as DecimalType).doubleValue * Math::pow(10,SF)
logDebug("SE9K WR Spannung Phase B: ", value)
postUpdate(se9k_VoltB, result)
rule se9k_VoltC_add
when Item se9k_VoltC_int received update
var Double result = (se9k_VoltC_int.state as DecimalType).doubleValue * Math::pow(10,SF)
logDebug("SE9K WR Spannung Phase C: ", value)
postUpdate(se9k_VoltC, result)
rule se9k_Watt_add
when Item se9k_Watt_int received update
var Double power = (se9k_Watt_int.state as DecimalType).doubleValue
if (power > 32767) power = power-(65536).doubleValue
var Double SF = (se9k_WattSF_int.state as DecimalType).doubleValue
var Double result = power * Math::pow(10,SF)
logInfo("[se9k] Watt: ", result.toString)
postUpdate(se9k_Watt, result)
rule se9k_Hz_add
when Item se9k_Hz_int received update
var Double SF = (se9k_HzSF_int.state as DecimalType).doubleValue
var Double result = (se9k_Hz_int.state as DecimalType).doubleValue * Math::pow(10,SF)
logDebug("SE9K WR Netzfrequenz: ", value)
postUpdate(se9k_Hz, result)
rule se9k_VA_add
when Item se9k_VA_int received update
var Double VA = (se9k_VA_int.state as DecimalType).doubleValue
if (VA > 32767) VA = VA-(65536).doubleValue
var Double result = VA * Math::pow(10,SF)
logDebug("SE9K WR Scheinleistung: ", value)
postUpdate(se9k_VA, result)
rule se9k_VAR_add
when Item se9k_VAR_int received update
var Double VAR = (se9k_VAR_int.state as DecimalType).doubleValue
if (VAR > 32767) VAR = VAR-(65536).doubleValue
var Double SF = (se9k_VARSF_int.state as DecimalType).doubleValue
var Double result = VAR * Math::pow(10,SF)
logDebug("SE9K WR reaktive Leistung: ", value)
postUpdate(se9k_VAR, result)
rule se9k_PF_add
when Item se9k_PF_int received update
var Double PF = (se9k_PF_int.state as DecimalType).doubleValue
if (PF > 32767) PF = PF-(65536).doubleValue
var Double SF = (se9k_PFSF_int.state as DecimalType).doubleValue
var Double result = PF * Math::pow(10,SF) /100
logDebug("SE9K WR Leistungsfaktor: ", value)
postUpdate(se9k_PF, result)
rule se9k_kWh_add
when Item se9k_Wh2_int received update
var Double SF = (se9k_WhSF_int.state as DecimalType).doubleValue
var Double resultWh = ((se9k_Wh1_int.state as DecimalType * 65536).doubleValue + (se9k_Wh2_int.state as DecimalType).doubleValue) * Math::pow(10,SF)
var Double Offset = (se9k_kWh_Jahr_Offset.state as DecimalType).doubleValue * 1000.0
var Double Jahr = (resultWh - Offset) / 1000.0
var String valueWh= resultWh.toString
var String wrjahr = Jahr.toString
logInfo("[se9k]  Wh: ", valueWh)
logInfo("SE9K WR Erzeugung seit 1.1. kWh: ", wrjahr)
var Double result = resultWh / 1000.0
postUpdate(se9k_kWh, result)
postUpdate(se9k_kWh_Jahr, Jahr)
rule se9k_DCA_add
when Item se9k_DCA_int received update
var Double SF = (se9k_DCASF_int.state as DecimalType).doubleValue
var Double result = (se9k_DCA_int.state as DecimalType).doubleValue * Math::pow(10,SF)
logDebug("SE9K WR Strom DC: ", value)
postUpdate(se9k_DCA, result)
rule se9k_DCV_add
when Item se9k_DCV_int received update
var Double SF = (se9k_DCVSF_int.state as DecimalType).doubleValue
var Double result = (se9k_DCV_int.state as DecimalType).doubleValue * Math::pow(10,SF)
logDebug("SE9K WR Spannung DC: ", value)
postUpdate(se9k_DCV, result)
rule se9k_DCW_add
when Item se9k_DCW_int received update
var Double DCW= (se9k_DCW_int.state as DecimalType).doubleValue
if (DCW > 32767) DCW = DCW-(65536).doubleValue
var Double SF = (se9k_DCWSF_int.state as DecimalType).doubleValue
var Double result = DCW * Math::pow(10,SF)
logDebug("SE9K WR Leistung DC: ", value)
postUpdate(se9k_DCW, result)
rule se9k_THS_add
when Item se9k_THS_int received update
var Double THS= (se9k_THS_int.state as DecimalType).doubleValue
if (THS > 32767) THS = THS-(65536).doubleValue
var Double SF = (se9k_THSSF_int.state as DecimalType).doubleValue
var Double result = THS * Math::pow(10,SF)
logDebug("SE9K Temperatur Kuehlkoerper: ", value)
postUpdate(se9k_THS, result)
rule se9k_Status_map
when Item se9k_Status_int received update
var String str="-"
if (se9k_Status_int.state == 1) str = "AUS"
if (se9k_Status_int.state == 2) str = "Nachtmodus"
if (se9k_Status_int.state == 4) str = “AN/Produktion”
logDebug("Status Wechselrichter:  ", str)
postUpdate(se9k_Status, str)
rule se9k_DID_map
when Item se9k_DID_int received update
var String str="-"
if (se9k_DID_int.state == 101) str = "einphasig"
if (se9k_DID_int.state == 102) str = "Split phase"
if (se9k_DID_int.state == 103) str = “dreiphasig”
postUpdate(se9k_DID, str)
rule se9k_Status__Vendor_map
when Item se9k_Status_vendor_int received update
var String str= se9k_Status_Vendor_int.state.toString
logDebug("Status Wechselrichter (Fehlermeldungen):  ", str)
postUpdate(se9k_Status_Vendor, str)
/etc/openhab2/sitemaps/solaredge9k.sitemap
sitemap solaredge9k label="solaredge9k" {
    Text item=se9k_Watt {
      	Frame label="Wechselrichter SE9k" {
                Text item=se9k_Watt
                Text item=se9k_kWh
                Text item=se9k_kWh_Jahr
      		Setpoint item=se9k_kWh_Jahr_Offset  minValue=-100000 maxValue=100000 step=0.1
                Text item=se9k_Hz
      		Text item=se9k_VA
                Text item=se9k_VAR
                Text item=se9k_PF
      		Text item=se9k_Amps
      		Text item=se9k_AmpA
                Text item=se9k_AmpB
                Text item=se9k_AmpC
                Text item=se9k_VoltA
                Text item=se9k_VoltB
                Text item=se9k_VoltC
                Text item=se9k_DCA
                Text item=se9k_DCV
                Text item=se9k_DCW
                Text item=se9k_THS
                Text item=se9k_Status
                Text item=se9k_Status_Vendor
      	Group item=se9kint label="Werte SE9K Wechselrichter (int)"
log:
retrieve item 'se9k_kWh_Jahr_Offset' for widget org.eclipse.smarthome.model.sitemap.Setpoint
2018-10-27 10:48:10.774 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.779 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_Hz' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.783 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_Hz' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.787 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_Hz' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.791 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.795 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_VA' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.800 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_VA' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.805 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_VA' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.810 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.815 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_VAR' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.820 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_VAR' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.826 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_VAR' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.831 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.836 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_PF' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.840 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_PF' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.842 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_PF' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.845 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.847 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_Amps' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.850 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_Amps' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.853 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_Amps' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.855 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.858 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_AmpA' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.861 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_AmpA' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.864 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_AmpA' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.866 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.869 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_AmpB' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.872 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_AmpB' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.874 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_AmpB' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.877 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.880 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_AmpC' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.883 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_AmpC' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.885 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_AmpC' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.888 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.891 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_VoltA' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.893 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_VoltA' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.896 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_VoltA' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.900 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.902 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_VoltB' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.905 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_VoltB' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.908 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_VoltB' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.910 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.913 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_VoltC' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.915 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_VoltC' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.918 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_VoltC' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.921 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.923 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_DCA' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.926 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_DCA' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.928 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_DCA' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.930 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.933 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_DCV' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.935 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_DCV' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.938 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_DCV' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.941 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.943 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_DCW' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.946 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_DCW' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.948 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_DCW' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.951 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.954 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_THS' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.957 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_THS' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.959 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_THS' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.961 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.964 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_Status' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.966 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_Status' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.968 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_Status' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.971 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.973 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_Status_Vendor' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.976 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_Status_Vendor' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.978 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9k_Status_Vendor' for widget org.eclipse.smarthome.model.sitemap.Text
2018-10-27 10:48:10.981 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Group
2018-10-27 10:48:10.983 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9kint' for widget org.eclipse.smarthome.model.sitemap.Group
2018-10-27 10:48:10.985 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9kint' for widget org.eclipse.smarthome.model.sitemap.Group
2018-10-27 10:48:10.988 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'se9kint' for widget org.eclipse.smarthome.model.sitemap.Group
Please learn to use code fences properly.
Sorry! Edit Done!
Those errors might all just be related to the fact that you just created the items. Can you please check that you installed and enabled the modbus (v1) binding?
The error is telling you that your sitemap includes Items like se9k_AmpA but that they can’t be found in the system.
There’ll be some error in your .items file preventing all or some of it from being read.
Missing bracket or quote maybe?
im installed the Modbus Binding over the Paper UI
Im using an SE4K inverter can be there the Problem ?
There are two modbus bindings, the old v1 and the new v2 (which will only show up in openHAB versions 2.4 onwards)
Choose carefully, they are not compatible at all.
The error log you have provided is to do with Items and sitemap, not bindings.
OK and where i can get v1 ?
In the PaperUI, go to Configuration → System → Add-On Management.
There is a switch called „Include legacy v1.x bindings“ and turn that on.This will make the V1 modbus binding show up and give you the option to install it (remove the V2 binding while you‘re at it).
thanks, changed from v2 to v1
But now i got a new error message:
2018-10-27 13:21:44.670 [ERROR] [ing.ModbusSlaveConnectionFactoryImpl] - connect try 1/3 error: connect timed out. Connection TCPMasterConnection@15a3c17[socket=Socket[unconnected]]. Endpoint ModbusTCPSlaveEndpoint@1166595[address=192.168.178.26,port=502]
2018-10-27 13:21:45.017 [ERROR] [ing.ModbusSlaveConnectionFactoryImpl] - connect try 1/3 error: Connection refused (Connection refused). Connection TCPMasterConnection@15a3c17[socket=Socket[unconnected]]. Endpoint ModbusTCPSlaveEndpoint@2eb250[address=192.168.178.26,port=502]
2018-10-27 13:21:45.586 [ERROR] [ing.ModbusSlaveConnectionFactoryImpl] - connect try 2/3 error: connect timed out. Connection TCPMasterConnection@15a3c17[socket=Socket[unconnected]]. Endpoint ModbusTCPSlaveEndpoint@2eb250[address=192.168.178.26,port=502]
2018-10-27 13:21:52.486 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'solaredge9k.items' has errors, therefore ignoring it: [3,19]: missing EOF at '“'
2018-10-27 13:21:53.527 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'solaredge9k.items' has errors, therefore ignoring it: [3,19]: missing EOF at '“'
2018-10-27 13:21:56.504 [ERROR] [ing.ModbusSlaveConnectionFactoryImpl] - connect try 1/3 error: connect timed out. Connection TCPMasterConnection@15a3c17[socket=Socket[unconnected]]. Endpoint ModbusTCPSlaveEndpoint@1166595[address=192.168.178.26,port=502]
There are some syntax errors in your items file.
Please check the configuration for your modbus target for ip adress and port, the connect errors say that it cannot connect. Also make sure that you have no other active modbus connections to the inverter, it can only handle one. There is a connection refused message that seems to indicate that the modbus server in the inverter is busy. There is no 3/3 error, which seems to indicate the the connections works after all. I occasionally get those errors on the first or second try as well sometimes.
now, connection is fixed (restart the inverter)
Syntax Errors fixed, there was some false qutoe types in the files .
Now i get Data from the Inverter HAPPY !
Two more Questions, Log 1: What happens by sitemap file ?
2018-10-28 09:58:38.878 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'solaredge9k.sitemap', using it anyway:
Linkable widget should contain either only frames or none at all
2018-10-28 09:58:38.885 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'solaredge9k.sitemap'
2018-10-28 09:58:39.961 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'solaredge9k.sitemap', using it anyway:
2018-10-28 09:58:39.974 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'solaredge9k.sitemap'
Log 2:
How can i fix that ?
2018-10-28 10:01:21.765 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'se9k_kWh_add': Could not cast NULL to org.eclipse.smarthome.core.library.types.DecimalType; line 136, column 22, length 41
This error is mostl likely a cosmetic error that appears when you upload a new sitemap and the parser tries to load it when the filesystem isn‘t fully synced.
Ok Thank you very much =)
One more Question - sorry :wink:
Can i See anywhere the Daily generated Power, Weekly, Monthly ?
At the moment i can see only “WR Erzeugung seit Jahresanfang” ?
No, you woumd have build those functions yourself and i.e save the values of the meter esch day at midnight for daily, at midnight on Monday for weekly and midnight of tje firdt of the month for montgly and then simply build the differenced whenever you read the meter. I didn‘t do that because the solaredge monitoringportal is quite good for that. I was more focused on getting the currently generated power w
quadi instantaneous so that i could steer my dim loads.
While i am still intrigued by openHAB (it sometimes does something… hehe, but for now it only loses most “things” all the time) and overlooked the “don’t use new modbus binding for 2.x”* part and was close to giving up on getting the three simple live figures in my SE9k+WND-Modbus-Meter: Production, House Consumption, Grid +/- to do exactly the same as Thomas, i.e. turning consumers on if excess is available (“hysteresis post”)…
I thought this would be a standard thing to do and took two days to no result other then I can now watch the SE-monitoring in the smartphone and then opening another app to remotely but manually flick a switch…
WHERE would I find the info how with the modbus 2 binding the whole setup should be ported, I am willing to help on that… maybe not so soon but come winter …
Hello Sven,
you would mostly find the documentation for the modbus2 binding in the add-on reference of the main openhab Website: https://www.openhab.org/addons/bindings/modbus/.
What would mostly Change is that modbus.cfg would go away and be replaced by a modbus.things file that tells the binding which channels to set up to read data and probably also how to Interpret the numbers read. As far as my cursory inspection of the doc goes, it seems that the binding can read float numbers directly and might not need my code to convert from uint16 or uint32 to float.
Consequently, the items definition would need to change and refer the channels that are defined in the things file. Finally, the code to convert the int values to float values could maybe be removed or need to be modified.
Once you have the data in the float items, all the rest of the code can remain unchanged.
Best,
Thomas
Hi
I have some problems to read the values for my solar edge smart meter that is connected to the inverter. What SW version do you have in the inverter that made it work for you?
BR
/Fredrik
Hi Ian
Looks like i have the same problems like you have. Have you been able to solve your problems? If you have how did you solve it?
BR
/Fredrik
Edit: Lost the quote but this is about reading values from the smart meter and only get 0 or 32xxx values.
I know, the thread is named “Reading Data from Solaredge…”, but I wonder if there is a chance to write data to the inverter.
What I would like to do is changing the Total-Power-Export-Value (which is limited to 70% in Germany) to a higher value, e.g. when charging my car.
I can make sure, that I will not export more than 70% of my peak power to the grid by reading my 2-way-electricity meter via SML.
May be someone can point me to something helpful…
Thank you!
