When writing some simple “proxy rules” (mapping between items associated with the Z-Wave binding and virtual items that are only used in rules, sitemaps, etc.) I normally do something like this:
rule "Proxy"
Item sSwitch_Phy received command
sendCommand(sSwitch_Vir, sSwitch_Phy.state)
This seems to work fine.
I have since day one been using a simple text editor (nano since I am working on Linux) but inspired by @rlkoshak’s constant talk about the wonders of “the openHAB Designer and Ctrl-Space”, I decided to give it a try,
The first thing I discovered was that the designer complained about my simple rules (as shown above). Playing along with the suggestions (using Ctrl-Space) I ended up with the following to please the designer:
rule "Proxy"
sendCommand(sSwitch_Vir.name.toString, sSwitch_Phy.state.toString)
This seems a little bit elaborate. Is this really how it is supposed to be written, or am I missing something here?
For some reason, the Designer is not understanding the other static method signatures for sendCommand in the BusEvent class. This is probably a bug with the Designer.
Although it’s unfortunate if there is a bug in the designer, I am glad to hear this as I was getting increasingly confused by this issue.
Going back to my inital example…
rule "Proxy"
…and looking at the method signatures in the BusEvent class, I wonder what would be the correct way of doing what I want (which is basically propagating a Command from one Switch item to another)?
Looking at it now, I can see two problems with my example:
When I receive a command on the item sSwitch_Phy, the state has not been updated yet, so I cannot really use the state information to determine what command to pass on to the next item (sSwitch_Vir).
There is no sendCommand method that natively accepts a State so I would have to type cast this to something else.
Q: When you receive a command on a Switch item, is there a way to determine what the command was (e.g. ON or OFF)?
I guess the alternative approach would be to have two rules:
rule "Proxy #1"
Item sSwitch_Phy received command ON
sendCommand(sSwitch_Vir, ON)
rule "Proxy #2"
Item sSwitch_Phy received command OFF
sendCommand(sSwitch_Vir, OFF)
Check out the example here - the last one shows how you can use the receivedCommand inside a rule.
FYI - I write all my rules using the item.sendCommand(<CMD>) syntax (or item.postUpdate(<STATE>). I personally find it easier to read when I am visually parsing my rules.
