I’d like to turn a dimmable light on at the last dimmable level. But unlike pushing the button on the wall (attached to a fibaro dimmer 2), the command “on” in a rule turns the light on with 100%. Any idea?
What works so far / my setup
z-wave stick gen5
fibaro dimmer 2
openhabian
with the basic ui i can set the dim level with a slider
the slider in the basic ui changes it’s position, if i change the dim level directly on the wall switch (attached to the fibaro dimmer 2)
