My setup has a chromecast in an A/V receiver and uses the harmonyhub to control everything.
The receiver and tv do not support CEC, but I want to emulate it with Openhab. I tried the chromecast binding, but it seems to only support sending commands. Nothing seems to be listening for events from the chromecast. I wanted to use that to trigger the correct activity on my HarmonyHub when a play/pause/stop is received.
I tried the chromecast component of Home Assistant, and it did succesfully receive the new states instantly.
This is really good. I’ve been using the OH2 Chromecast binding, but it doesn’t get updates about the status properly so this looks a lot better.
I use my Google Home device to say alerts etc, some of them at late at night so I want a rule that will reduce the Google home volume but only if it’s not playing some music etc.
This would appear more functional than the standard chromecast binding. Would this be something that can be incorporated to openhab, or is the functionality of pychromecast not present in whatever java lib is being used in the current binding?
The OH Chromecast binding definitely receives state. I use it to trigger both Harmony and speaker configurations when applications like Pandora start.
I’ve been in the midst of a giant remodel and all my home automation is currently not connected, so maybe something broke recently?
You can get a whole lot of information from the plug-in. Just make sure you look into the advanced settings. I know, I made one of the last big updates to it.
