Hello!
Is it possible to receive 433Mhz TCM temperature sensor from cheap weather stations with CUL?
I know this from FHEM and there i can activate it very easily.
Thank you!
Hello!
Thank you!
I presume that is possible
Not sure what CUL is but code from wheather stations is often OregonScientific code. ’ If that is the case, you may want to try the rfxcom binding I think that receives Oregon
