my xiaomi button switches send a trigger-command to a channel and then i can get the command with this lines inside my rule:
rule "Xiaomi Button Switch 1"
Channel "mihome:sensor_switch:158d00012345678:button" triggered
var actionName = receivedEvent.getEvent()
switch(actionName) {
case "SHORT_PRESSED": {
logInfo("RULES", "Xiaomi 1 triggered SHORT_PRESSED")
But this is only working with this channel. How can i do this with a switch or another item?
rule "Test Item 1"
item test_item_1 received update
logInfo("RULES", "test_item_1 received the following: " + actionName)
Can someone tell me, how i have to change / rewrite my second rule, so that this is working?
I currently get this error-message:
2018-05-04 10:42:38.161 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Test Item 1': The name 'receivedEvent' cannot be resolved to an item or type; line 182, column 19, length 13
I highly recommend using VSCode with the openHAB extension.
You should have seen all sorts of errors in the log.
Capitalize the “i” in Item in the trigger
Rules triggered by Items receive commands or changes, but not Events so I suspect receivedEvent is null
rule "Test Item 1"
Item test_item_1 received update
var actionName = test_item_1.state.toString
This was not my original rule, i have item already written with a capitalized “I”. I already use vscode and i was knowing before, that the rule is not correct, but i had no idea, how to solve this.
But if i check for the state.toString of the item, i will only get the state after the command? In my case i can send “100” or “down” to my rollershutter item. Both states after the command are “100”. But i want to get the real command, not the result of this command.
Example:
I send “down” to the rollershutter, after half of the way i send “stop”. Now i want to get the command “stop” as actionName. But i will get “50” - for 50% closed.
You are triggering the rule using received update. The rule will not trigger until test_item_1 is set to the new state from the update so using test_item_1.state.toString will reflect the latest state of the Item.
Then you need to use received command instead of received update and use the receivedCommand implicit variable.
