Recommended heap size
That is 253,000k or aka 253megabyte
If you want some heap guidence try this binding which is found in the Marketplace, and it will give a better break down of your heap usage in the DEBUG level logs and also give you a graph. If you need to change the heap it will give you a WARN message in the logs.
