I just tried connecting to my Dutch smartmeter over rfc2217 using the DSMR binding by @Hilbrand while also being connected to a Plugwise Stick on Ubuntu. In the end I got them both working at the same time.
I used a .things file for configuring the rfc2217 connection for the DSMR Thing:
The UI wouldnāt allow me to enter a port because it only allows for selecting known serial ports. Adding them using gnu.io.rxtx.SerialPorts will probably not work because these rfc2217:// URL prefixes are an openHAB convention.
Another issue with these rfc2217 connections is that not all serial port operations properly work. For the DSMR binding it would throw an exception:
23:02:41.156 [DEBUG] [.device.connector.DSMRSerialConnector] - Port does not support requested port settings (invalid dsmr:portsettings parameter?): rfc2217://192.168.1.26:3000
org.eclipse.smarthome.io.transport.serial.UnsupportedCommOperationException: gnu.io.UnsupportedCommOperationException
at org.eclipse.smarthome.io.transport.serial.rxtx.RxTxSerialPort.enableReceiveThreshold(RxTxSerialPort.java:157) ~[?:?]
at org.openhab.binding.dsmr.internal.device.connector.DSMRSerialConnector.open(DSMRSerialConnector.java:158) [bundleFile:?]
at org.openhab.binding.dsmr.internal.device.connector.DSMRSerialConnector.open(DSMRSerialConnector.java:119) [bundleFile:?]
at org.openhab.binding.dsmr.internal.device.DSMRSerialAutoDevice.start(DSMRSerialAutoDevice.java:152) [bundleFile:?]
at org.openhab.binding.dsmr.internal.device.DSMRSerialAutoDevice.restart(DSMRSerialAutoDevice.java:162) [bundleFile:?]
at org.openhab.binding.dsmr.internal.device.DSMRDeviceRunnable.run(DSMRDeviceRunnable.java:82) [bundleFile:?]
Caused by: gnu.io.UnsupportedCommOperationException
at gnu.io.rfc2217.TelnetSerialPort.enableReceiveThreshold(TelnetSerialPort.java:948) ~[?:?]
at org.eclipse.smarthome.io.transport.serial.rxtx.RxTxSerialPort.enableReceiveThreshold(RxTxSerialPort.java:155) ~[?:?]
... 6 more
After I commented those incompatible operations, and used the updated/recompiled binding no exceptions were thrown and the connection using rfc2217 with ser2net properly worked.
I see that the ZWave Binding by @chris is using the same operations that will throw exceptions when used with rfc2217 connections.
There are others too, see UnsupportedCommOperationException in this nrjavaserial TelnetSerialPort.java
So my conclusions are:
it should be possible to get physically connected devices and rfc2217 devices working at the same time
there are Paper UI limitations that currently make it difficult to use these rfc2217 connections and itās probably best to configure them using .things files
itās not guaranteed that all operations on normal serial ports also work on rfc2217 connections, thus they are currently not transparent or a drop in replacement for a normal serial port
Congratulations on having rfc2217 run with the DSMR binding. I would have wanted to see the same with ZWave, but I must agree with both of you that rfc2217 is not a transparent/drop-in replacement for a normal serial port.
Regrettably, I will have to leave this for others to resolveābut based on the comments from @chris, I assume this is unlikely to get looked at by OH developers. Unfortunately, this issue, combined with the locking-related abort traps when using the ZWave binding on FreeBSD is a blocker for my move towards OH 2 or 3āhaving the ZWave stick on a remote machine, away from the server, is a must for my installation.
I would still be happy to occasionally test things if anyone needs that, please ping me.
Above all: thank you for your help. Much appreciated.
I have first tried with a locally socatāed port. Unfortunately, that does not work, because the binding throws Abort traps under FreeBSD. I have gone to the lengths of debugging it down to nrjavaserial to eliminate the library as the source of the aborts. I found that nrjavaserial works fine as of 5.1.1+ (some issues got fixed). However, running OH 2.5 with the new version of the library still breaks the runtime.
I was hoping to just connect ZWave binding to the remote ser2net just like RFXCOM binding does it, but @chris has wisely explained that it would not be possible to make ZWave do that, as instead the ZWave binding must rely on the rest of OH for serial port functionality, with or without RFC2217. He also explained that very few users need the RFC2217 and so it is not going to happen. I am of the opinion that having a location remote from the server for any antenna-like devices is essential, but that is only my opinion, I suppose.
Since RFC2217 is essentially broken/incomplete in OpenHAB as of now, and since I cannot use ZWave over a socatāed port on FreeBSD that gives me no other options that I could think of.
For completeness, ZWave is also not working on FreeBSD using a locally plugged-in ārealā USB stick, see this long-running discussion, in which a good number of other users went through the same iterations as I did, eventually giving upāI just tried to debug it a bit further, I suppose.
Approx 40 ZWave switches, sockets and a couple of rollers. Walls are stone, approx 1.5m in thickness, mostly 19th century. ZWave works very well for me when the antenna is in the attic. I do not want my server to be there.
Because I like FreeBSD and I have substantial experience of it. I no longer want to run OH 1.8.3 on a Pi with a Linux. If I cannot run OH 2/3 on FreeBSD I would rather not use OH anymore.
