Hey,
I have a security keypad in my sitemap which is mapped to 12 buttons.
I am looking at what buttons are pressed and adding them to a code string. when i press the tick button, if that code string matches a predetermined code, it unlocks everything.
This is a very simple form of security ive been playing around with for fun.
But how can i make this rule shorter. I know i can look at what button was pressed, and then send the last letter/number as string in that button name. But how would i word it.
sitemap
Switch item=AlarmKeypad label="Passcode" icon="keypad" mappings=[KEY1="1", KEY2="2", KEY3="3"]
Switch item=AlarmKeypad label="" icon="none" mappings=[KEY4="4", KEY5="5", KEY6="6"]
Switch item=AlarmKeypad label="" icon="none" mappings=[KEY7="7", KEY8="8", KEY9="9"]
Switch item=AlarmKeypad label="" icon="none" mappings=[KEYN="X", KEY0="0", KEYY="✓"]
Text item=KeypadString label="Code is [%s]" icon="none" valuecolor=[KeypadString=="Correct"="green",KeypadString=="Incorrect"="red"]
Items
String AlarmKeypad
Switch Unlocked
String KeypadString
Rule
rule "keypad"
Item AlarmKeypad received update
if (AlarmKeypad.state == "KEYN")
if (lockTimer !== null)
lockTimer.cancel
lockTimer = null
KeypadString.postUpdate("")
Unlocked.sendCommand(OFF)
if (AlarmKeypad.state == "KEY0")
KeypadString.postUpdate(KeypadString.state.toString + "0")
AlarmKeypad.postUpdate(NULL)
if (AlarmKeypad.state == "KEY1")
KeypadString.postUpdate(KeypadString.state.toString + "1")
if (AlarmKeypad.state == "KEY2")
KeypadString.postUpdate(KeypadString.state.toString + "2")
if (AlarmKeypad.state == "KEY3")
KeypadString.postUpdate(KeypadString.state.toString + "3")
if (AlarmKeypad.state == "KEY4")
KeypadString.postUpdate(KeypadString.state.toString + "4")
if (AlarmKeypad.state == "KEY5")
KeypadString.postUpdate(KeypadString.state.toString + "5")
if (AlarmKeypad.state == "KEY6")
KeypadString.postUpdate(KeypadString.state.toString + "6")
if (AlarmKeypad.state == "KEY7")
KeypadString.postUpdate(KeypadString.state.toString + "7")
if (AlarmKeypad.state == "KEY8")
KeypadString.postUpdate(KeypadString.state.toString + "8")
if (AlarmKeypad.state == "KEY9")
KeypadString.postUpdate(KeypadString.state.toString + "9")
rule "keypadstate"
Item AlarmKeypad received command KEYY
if (KeypadString.state == "XXXX")
KeypadString.postUpdate("Correct")
Thread::sleep(750)
Unlocked.sendCommand(ON)
lockTimer.cancel
lockTimer = null
lockTimer = createTimer(now.plusMinutes(3))[|
else
KeypadString.postUpdate("Incorrect")
createTimer(now.plusSeconds(1)) [|
