Hi, I need help.
I have a grafana graphic that I’m showing with an iframe. It works fine, but I do not get it to refresh every time.
I’m working with habpanel
Hi, I need help.
Hi, it’s working well. Check if it is in web page with grafana port 3000 refreshed.
Hi @Jozef_Szabo,
I may have probably the same problem. Can you explain a bit closer what you mean with your answer?
Where can I check if Grafana port 3000 is refreshed. Besides, I am using port 3001. Is this a problem. Can I configure that port 3001 is also refreshed?
Thanks!
