Hi there! I created a script to update a image every second in the /html folder. When I put the URL (http://X.X.X.X:8080/static/camara.jpeg) in Basic UI with refresh=1000, it’s work fine. But when I made an image card o webframe card on Main UI, I can’t get the update to work and the image is frozen.
Solved! I used HTTP Binding to create a “Things” with the base URL : http://x.x.x.x:8080/static/camara.jpeg, I configured the refresh time and the corresponding item, which I placed in the webframe card . And it works
