Regex find string in website
I have a local webside giving me some values:
AH0648EY:Consumption_Tarif8_OBIS_1.8.8:
AH0648EY:Consumption_Tarif9_OBIS_1.8.9:
AH0648EY:Consumption_CalculatedPower_OBIS_1.99.0:0.0000
AH0648EY:Consumption_Power_OBIS_1.7.0:
AH0648EY:Delivery_Total_OBIS_2.8.0:
AH0648EY:Delivery_Tarif1_OBIS_2.8.1:
Now I want to get that value (marked bold) in a minute delay as a String.
Means: all that follows after “AH0648EY:Consumption_CalculatedPower_OBIS_1.99.0:” till the end of that line
What would be the right regex expression?
Thanks for any help
wipwap
Not really an RegEx expert, but the following is working:
(?<=AH0648EY:Consumption_CalculatedPower_OBIS_1.99.0:)\d+.\d+
try that with regex101.com
Of course the string must be the same. if the numbers change, you can replace them with \d
Hi Sascha,
thx for the quick reply.
Whe I put this in my items file:
String KWhEinspeisung “Value:[%s]” { http="<[http://192.168.1.102/plugins/smartmeter/index.php:1000:REGEX(?<=AH0648EY:Consumption_CalculatedPower_OBIS_1.99.0:)\d+.\d+]" }
I get the following error:
018-10-29 23:44:36.433 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model ‘cyberstoeckli.items’ has errors, therefore ignoring it: [211,45]: mismatched character ‘d’ expecting set null
[211,164]: mismatched input ‘+’ expecting RULE_STRING
[211,170]: mismatched character ‘<EOF>’ expecting ‘"’
What am I missing? Do I have to excape sth?
thx
I checked your regex with notepad++. Works.
But: When I put this in my items file:
String  KWhEinspeisung  { http="<[http://192.168.1.102/plugins/smartmeter/index.php:1000:REGEX((?<=AAH0648EY:Consumption_CalculatedPower_OBIS_1.99.0:)\\d+.\\d+)]" }
I only get null als value…
I still did not solve my problem. The html source of the webside ist like this:
AH0648EY:Last_Update:2018-10-30 12:16:27
AH0648EY:Last_UpdateLoxEpoche:310133787
AH0648EY:Consumption_Total_OBIS_1.8.0:022842.106
AH0648EY:Consumption_Tarif1_OBIS_1.8.1:012052.140
AH0648EY:Consumption_Tarif2_OBIS_1.8.2:010789.966
AH0648EY:Consumption_Tarif3_OBIS_1.8.3:
AH0648EY:Consumption_Tarif4_OBIS_1.8.4:
AH0648EY:Consumption_Tarif5_OBIS_1.8.5:
AH0648EY:Consumption_Tarif6_OBIS_1.8.6:
AH0648EY:Consumption_Tarif7_OBIS_1.8.7:
AH0648EY:Delivery_Total_OBIS_2.8.0:000505.684
AH0648EY:Delivery_Tarif1_OBIS_2.8.1:000505.684
AH0648EY:Delivery_Tarif2_OBIS_2.8.2:000000.000
AH0648EY:Delivery_Tarif3_OBIS_2.8.3:
AH0648EY:Delivery_Tarif4_OBIS_2.8.4:
AH0648EY:Delivery_Tarif5_OBIS_2.8.5:
AH0648EY:Delivery_Tarif6_OBIS_2.8.6:
AH0648EY:Delivery_Tarif7_OBIS_2.8.7:
AH0648EY:Delivery_Tarif8_OBIS_2.8.8:
AH0648EY:Delivery_Tarif9_OBIS_2.8.9:
AH0648EY:Delivery_CalculatedPower_OBIS_2.99.0:0.4966
AH0648EY:Delivery_Power_OBIS_2.7.0:
AH0648EY:Total_Power_OBIS_15.7.0:
AH0648EY:Total_Power_OBIS_16.7.0:
#EOF
In my Items file I have the following line:
String  Loxoneweb  "Loxone: [%s]" { http="<[http://192.168.1.102/plugins/smartmeter/index.php:6000:REGEX((.*))]" }
in the openhab_log I can see, when the side is read. All values are displayed.
I would like to write a rule, that extracts one value. The number behind that string: “AH0648EY:Delivery_Total_OBIS_2.8.0:”.
the following statement does not work:
	val newVal = transform("REGEX", "(?<=AH0648EY:Delivery_Total_OBIS_2.8.0:)\\d+\\.\\d+", Loxoneweb.state.toString )
newVal is always null. Someone else any Idea? I dont know what I am doing wrong.
Problem (auf unschöne Art) selber gelöst mit diversen Substring Operationen. Beispiel:
	val newVal = Loxoneweb.state.toString
	LoxoneReadTime.postUpdate(newVal.substring(newVal.indexOf('AH0648EY:Last_Update:')+"AH0648EY:Last_Update:".length,newVal.indexOf('AH0648EY:Last_UpdateLoxEpoche:')-1))
	Einspeisung_Total.postUpdate(newVal.substring(newVal.indexOf('AH0648EY:Delivery_Total_OBIS_2.8.0:')+"AH0648EY:Delivery_Total_OBIS_2.8.0:".length,newVal.indexOf('AH0648EY:Delivery_Tarif1_OBIS_2.8.1:')-1))
Unlike the way regex101.com works, in OH you must have a REGEX that matches the entire String and use parens to identify the part you want to return.
".*AH0648EY:Consumption_CalculatedPower_OBIS_\d.\d\d.\d:(\d+.\d+).*"
Note the addition of the .* at the beginning and end. This will match the rest of the String. Also note that the parens are around the Number as that is the part you want returned.
Hi Rikoshak
that looks more elegant :wink: but: Do I have to double escape the \ like \ ?
Yes I do. It works perfectly.
thx
