I have a JSONPATH that pulls out temp of my batteries, but the value includes a space and C so I can’t convert to F. So if the temp is 23 I get back “23 C” (minus the “”). I have that in a var, how do I strip out all but the number with REGEX in a rule?
My full var right now is: var Number battery_temp = new Double(transform("JSONPATH", "$.devstatus.ports[?(@.Port==10)][0].Batt_temp", json))
Then: postUpdate(Battery_Temp, (battery_temp * (9 div 5) + 32)
2015-12-05 17:43:59.673 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule 'Outback JSON parsing': Could not invoke method: java.lang.String.split(java.lang.String,int) on instance: 23 C
rule: var String battery_temp = transform("JSONPATH", "$.devstatus.ports[?(@.Port==10)][0].Batt_temp", json).split(" ")[0]
instead of the more traditional Java array reference:
<array>[<index>]
Using the above, this sample rule works (log output below):
import org.openhab.core.library.items.*
rule "test split rule"
Time cron "0/5 * * * * ?"
var String t = "10 C"
var String[] u = t.split(" ")
logInfo("test-split", "Before: " + t + " After: " + u.get(0))
Here’s the output:
16:30:05.003 DEBUG o.o.m.r.i.e.ExecuteRuleJob[:53]- Executing scheduled rule 'test split rule'
16:30:05.018 INFO o.o.model.script.test-split[:53]- Before: 10 C After: 10
16:30:10.004 DEBUG o.o.m.r.i.e.ExecuteRuleJob[:53]- Executing scheduled rule 'test split rule'
16:30:10.018 INFO o.o.model.script.test-split[:53]- Before: 10 C After: 10
Thanks Mark! That worked, but even tho I am saying var Number, it does not work like a number. As as an example if I add + 1 I get 231 rather then 24.
var String battery_temp_string = new String(transform("JSONPATH", "$.devstatus.ports[?(@.Port==10)][0].Batt_temp", json))
var Number battery_temp = battery_temp_string.split(" ").get(0)
