@Tommy_Lian Be aware that the " " definition of serial is a string.
And the \ is the escape sign which lets you use something like " in a string by writing \". As the backslash has a special function you need to escape it, with an escape sign, so \\ wil give you \ in the string.
The code you posted made sense and worked in regex101.com, but when i added it to the item it still gives error.
this time;
[WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model βdefault.itemsβ has errors, therefore ignoring it: [7,80]: mismatched character βdβ expecting set null
That last edit did the trick. Thanks a lot for the help. Regex seems a bit hard to get into. I can use this formula for all my sensors over the serialstream.
