Hi @michi, the SSML is fantastic! I’ve been hoping you would add this feature since I heard of it.
I tested with my group of 12 echos (in the US) and see the same issue that we’ve been having with plain text. The following message repeats several times corresponding to random devices that don’t play after any given command.
2019-01-12 09:07:34.554 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.handleCommand()' on 'org.openhab.binding.amazonechocontrol.internal.handler.EchoHandler@1ff50d0': POST url 'https://alexa.amazon.com/api/behaviors/preview' failed: Bad Request
org.openhab.binding.amazonechocontrol.internal.HttpException: POST url 'https://alexa.amazon.com/api/behaviors/preview' failed: Bad Request
at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequest(Connection.java:585) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.executeSequenceNode(Connection.java:1119) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.executeSequenceCommand(Connection.java:1104) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.executeSequenceCommandWithVolume(Connection.java:1095) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.sendAnnouncement(Connection.java:1061) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.EchoHandler.startTextToSpeech(EchoHandler.java:714) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.EchoHandler.handleCommand(EchoHandler.java:600) ~[?:?]
at sun.reflect.GeneratedMethodAccessor27086.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [102:org.eclipse.smarthome.core:0.10.0.201812141650]
at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [102:org.eclipse.smarthome.core:0.10.0.201812141650]
at com.sun.proxy.$Proxy194.handleCommand(Unknown Source) [265:org.openhab.binding.amazonechocontrol:2.5.0.Beta_02]
at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:75) [109:org.eclipse.smarthome.core.thing:0.10.0.201812141650]
at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:49) [109:org.eclipse.smarthome.core.thing:0.10.0.201812141650]
at sun.reflect.GeneratedMethodAccessor174.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [102:org.eclipse.smarthome.core:0.10.0.201812141650]
This is an interesting little quirk… On the Echo show it displays the text command:
jwiseman
(Mr. Wiseman (OH 3.2 FINAL on Pi4))
#1420
I keep seeing discussions about calling a bunch of echo’s at once with the same message. I haven’t figure out how to do this w/o writing a rule that has 1 echo - one after another - saying the same thing.
Can you provide a rule example that calls all 12 echo’s at the same time to send the same message? I also have 12 echo’s (US) and I’m very interested in this rule.
@jwiseman: It would be nice, If you could test one more thing, the new api calls needs the customerId in two places and I’am not sure if they are both the account customer id or device customer id. Could you test an SSML text with one of your echos with the other owner?
Oh, thank you for this hint, I have not seen yet, that there is another alarmType for this. I will provide an additional channel for this is the next version.
jwiseman
#1425
It worked! The Echo Dot is under my account; not my wife’s which is what OH runs under.
Echo_Jay_textToSpeechVolume.sendCommand('60')
Thread::sleep(2000) // 2 second wait
Echo_Jay_TTS.sendCommand('<speak>Excuse me Jay,<break time="3s"/> I detect <emphasis level="strong">your phone</emphasis>,<break time="3s"/> so you must be home now.</speak>')
Best, Jay
jwiseman
#1426
nextAlarm option showing UNDEF in HabPanel
I’ve implemented the nextAlarm option in order to tell the kids that an alarm is NOT set on their Echo’s when they go to bed Sun - Thur @ 8:35 pm.
The issue I can’t seem to resolve is; it’s showing UNDEF in HabPanel when one isn’t set. Is there anyway to show something like “Not Set” or “01/01/2000” vs. UNDEF?
I don’t think a MAP file will work because when one is set; the transformation wouldn’t work with the date/time value, am I thinking correctly on this?
The nextAlarm is a DateTime variable (read only) so I’m not sure how to do this?
It doesn´t matter as the mapping wouldn´t be used if there´s a “correct” value.
It would create an log entry that says cannot transform 01/01/2000 with AlexaAlarm.map
