Hi! I don’t know if here is the right place for my problem, but since Version 2.5.7 I can’t use PaperUI and HABPanel. After a long research, I found out, that the problem is since Version 2.5.7. if I do a downgrade to the latest 2.5.6 Snapshot everything works fine.
The Problem is, that in PaperUI I get an ERROR 500 - Internal Server Error when I click on the control Button, or on the Item list. In the REST UI I can’t get the item list, too. And HABPanel, brings up an error, that there is no connection to habpanel. If I downgrade or even uninstall the amazonechocontroll add-on, everything works fine.
In the logs there is nothing to find and it took me weeks to find out, that the binding is the problem. I am using the docker Version, and so I have a good test environment to play around. My production openhab is still on openhab Version 2.5.6. My Test Stage is on the lates 2.5.8 docker image.
Hope someone could give me some hints, how I can solve that problem. What I did so far:
- uninstalled the binding
- cache clearing
- Update and downgrade to snapshot versions 2.5.6 - 2.5.9
- check the log files
- restart the container
- tried other openhab versions
- uninstallation via bundle: command
- up and down grade via bundle: command
- delete all things and items
- delete the amazon account thing
- logged out the amazon account
So perhaps I missed something and someone could help me out with that problem.
best regards
Andreas
